VE staring at me like deer in headlights [message #613483] |
Sat, 08 July 2006 16:24 |
Installed 3.2 eclispe_SDK
VE,EMF,GEF,RCP,blah blah blah all from 3.2 releases
Open up eclipse and open up a class in VE and it has a nice blank screen.
1. Does it not "parse" and show the layout as programmed?
Create "new" visual class using VE
1. Creates (for example) a new shell but the layout (VE) shows nothing.
2. I can add a SWT widget but it puts the source into the code - then goes
away visualy (code still has widget created).
I KNOW its me because I'm from MFC/Windows world and this java thing has
me all excited but getting this stuff to work is proving...well like
learning MFC all over again ;)
OH! Opening up a previously made class with SWT (I used the SWT controls
example code output and created a test class out of it-it uses SWT of
course) but VE opens up the window (again blank :( ) But only allows Swing
controls in the pallet - no SWT whatsoever... preplexing....
Thanks for your response.
Joe
FUDForum. Page generated in 0.03765 seconds
