Home » Eclipse Projects » Dali » Migration from Dali 2.0 to 2.1
Migration from Dali 2.0 to 2.1 [message #613102] Tue, 02 December 2008 20:06
Paul Fullbright is currently offline Paul FullbrightFriend
(Reposted from mailing list)
I just moved up to Dali 2.1 from Dali 2.0 and ran into a few API changes
that I'm not sure how to fix. I was able to use the wiki page
(http://wiki.eclipse.org/Dali_Provisional_API_Changes) to figure most
things out, but I have questions on a few others.
1. Currently I am using:
JptDbPlugin.instance().getConnectionProfileRepository().conn ectionProfileNamed(profileName);
This returned a ConnectionProfile object. It looks like I'm supposed to
use a ConnectionProfileFactory instead, is the following the best way to
do this:
JptDbPlugin.instance().getConnectionProfileFactory().buildCo nnectionProfile(profileName);
2. Currently I'm doing something like this to get the entity mappings
defined in the orm.xml file.
for (Iterator<MappingFileRef> mappingFiles =
persistenceUnit.mappingFileRefs(); mappingFiles.hasNext();) {
MappingFileRef mappingFileRef = mappingFiles.next();
OrmXml ormXml = mappingFileRef.getOrmXml();
EntityMappings entityMappings = ormXml.getEntityMappings();
The following method no longer exists: mappingFileRef.getOrmXml()
I wasn't able to find any information on this change in the wiki page.
Is there a new way I should be handling this situation?
3. I have a bunch of errors around setting and getting Temporal types.
It sounds like I need to use these new ConvertibleMapping objects.
Currently my code looks like this:
((ColumnMapping)mapping).setTemporal(TemporalType.DATE);
and
TemporalType temporalType = ((ColumnMapping)mapping).getTemporal();
I found a few example in your plugins showing how to get TemporalTypes:
if (this.javaIdMapping.getConverter().getType() ==
Converter.TEMPORAL_CONVERTER) {
org.eclipse.jpt.core.context.TemporalType javaTemporalType =
((TemporalConverter) this.javaIdMapping.getConverter()).getTemporalType();
Is this the best way to go about finding the TemporalType? I assume if
the mapping has no Temporal_Converter then that means no TemporalType
has been set on the mapping?
I wasn't able to find a good example of setting a Temporal type. Would I
just add a new TemporalConverter to my mapping and then set the value? I
wasn't sure if I could just add a new one because the javadoc in
ConvertibleMapping says calling setSpecifiedConverter(String) will
remove any old converters. Is it safe to do that?
4. Lastly I had been using a class
org.eclipse.jpt.core.context.orm.PersistenceUnitDefaults which no longer
seems to exist. I didn't see anything in the API change doc about this.
Is there something new I should be using instead?
Thanks for your help,
Chris
_______________________________________________
dali-dev mailing list
dali-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/dali-dev
Previous Topic:[Fwd: [dali-dev] questions on monitoring changes on JPA Model]
Next Topic:[Fwd: [dali-dev] Many to many relationship problem]
Current Time: Thu Apr 02 10:50:35 GMT 2020
Powered by FUDForum. Page generated in 0.01913 seconds
