Home » Archived » Eclipse Communications Framework (ECF) » Remote Services Registration
Remote Services Registration [message #609278] |
Fri, 24 November 2006 08:04 |
Paul Woodward Messages: 11 Registered: July 2009 |
Hi Guys,
I've been experimenting with the RemoteService example and unit test (0.9.3) and I've hit a snag...
It seems that all of the remote clients have to be created prior to registering any services in order for them to be able to obtain a reference to the service.
Here's how to show it: take all of the unit tests in RemoteServiceTest and amalgamate the funtions, in order into a single test and remote all the old test cases. You should get something similar to:
public void testAll() throws Exception {
IContainer clientOne = ContainerFactory.getDefault().createContainer(CONTAINER_CLIE NT_NAME);
assertNotNull(clientOne);
System.out.println("TEST clientOne id=" + clientOne.getID());
IContainer clientTwo = ContainerFactory.getDefault().createContainer(CONTAINER_CLIE NT_NAME);
assertNotNull(clientTwo);
System.out.println("TEST clientTwo id=" + clientTwo.getID());
ID serverID = IDFactory.getDefault().createStringID(GENERIC_SERVER_ID);
Object[] args = new Object[] { serverID };
IContainer server = ContainerFactory.getDefault().createContainer(GENERIC_CONTAI NER_SERVER_NAME, args);
assertNotNull(server);
clientOne.connect(serverID, null);
IRemoteServiceContainerAdapter remoteContainerOne = (IRemoteServiceContainerAdapter) clientOne.getAdapter(IRemoteServiceContainerAdapter.class);
assertNotNull(remoteContainerOne);
clientTwo.connect(serverID, null);
IRemoteServiceContainerAdapter remoteContainerTwo = (IRemoteServiceContainerAdapter) clientTwo.getAdapter(IRemoteServiceContainerAdapter.class);
assertNotNull(remoteContainerTwo);
IRemoteServiceRegistration remoteServiceRegistration = remoteContainerOne.registerRemoteService(new String[] { org.eclipse.ecf.tests.remoteservice.IConcat.class.getName() }, new ConcatImpl(), null);
waitTime(2000);
System.out.println(remoteServiceRegistration.getReference(). isActive());
remoteContainerTwo.addRemoteServiceListener(new IRemoteServiceListener() {
public void handleServiceEvent(IRemoteServiceEvent event) {
System.out.println("handleServiceEvent(" + event + ")");
// THIS TEST ALWAYS BREAKS - WHY?
IRemoteServiceReference[] refsOne = remoteContainerOne.getRemoteServiceReferences(null, org.eclipse.ecf.tests.remoteservice.IConcat.class.getName(), null);
assertTrue(refsOne.length > 0);
IRemoteServiceReference[] refs = remoteContainerTwo.getRemoteServiceReferences(null, org.eclipse.ecf.tests.remoteservice.IConcat.class.getName(), null);
assertTrue(refs.length > 0);
IRemoteServiceReference remoteServiceReference = refs[0];
IRemoteService remoteService = remoteContainerTwo.getRemoteService(remoteServiceReference);
assertNotNull(remoteService);
IConcat runnable = (IConcat) remoteService.getProxy();
String result = runnable.concat("ECF ", "is cool");
System.out.println("TEST RESULT: " + result);
If you move the code for creating remoteContainerTwo below the remoteServiceRegistration then querying it for remote services will yield no results.
Logically this is bizarre - it's like saying all clients of remote services must exist before the remote service does - or am I doing something dumb?
The other bizarre thing is that if you query the remoteContainer in which you registered the service, then it comes back with no results either.
Thanks in advance,
Paul
Re: Remote Services Registration [message #609286 is a reply to message #609278] |
Fri, 24 November 2006 17:43 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Paul,
Paul Woodward wrote:
> Hi Guys,
> waitTime(2000);
> Thanks in advance,
> Paul
Re: Remote Services Registration [message #609288 is a reply to message #609278] |
Fri, 24 November 2006 17:56 |
Hi Paul,
Sorry about the empty posting.
> Hi Guys,
> waitTime(2000);
I think this is just another bug and should be filed as such. I suspect
the reason is that when container two is connected the remote service
registry *should* be replicated to the newly joined container (two). It
*is* being replicated when the service is registered and the two
containers are already joined, but I think it's not being replicated
properly when a new container joins AFTER the registration has occurred
(the 'late joiner' situation).
This is the 'not implemented yet' bug mentioned in previous posting.
I'll try to address these bugs this weekend Nov 25 if I have the chance.
Scott
> Thanks in advance,
> Paul
Re: Remote Services Registration [message #609290 is a reply to message #609284] |
Fri, 24 November 2006 19:44 |
Hi Folks,
I've filed this as a bug and fixed it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=165815
Note I have *not* yet filed the other bug from Paul's posting so Paul
please do that.
Also added test:
public void testGetRemoteServiceReferenceLocal() throws Exception {
IRemoteServiceReference[] refs = remoteContainerOne
.getName(), null);
In RemoteServiceTestClass.
Scott
Scott Lewis wrote:
> Hi Paul,
> Please file this as a bug. The reason is simply that the local access
> to locally registered remoteservices (i.e. remoteContainerOne calling
> getRemoteServiceReferences for a remoteservice it has registered) is not
> yet implemented.
> I'll address the other issues in another posting.
> Scott
>> Hi Rem,
>> > ame(), null);
>> > > However, with regards to this test failure, can you
>> > provide us with some > additional information? Does the
>> assertion just fail
>> > and that's it? Does > an exception get thrown? Are you using
>> Java 1.6? The
>> > issue may be > identical to what's been reported at bug #161684.
>> > > https://bugs.eclipse.org/bugs/show_bug.cgi?id=161684
>> No exceptions, just the assertion that fails. I'm using Java 1.5.
>> Cheers, Paul
Re: Remote Services Registration [message #609291 is a reply to message #609288] |
Sat, 25 November 2006 22:45 |
Hi Folks,
I filed this as bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=165848
It turns out that this was just a relatively small error in logic for
when to replicate the registry contents...it was doing it in the case of
introducing new service *after* connect, but not doing it properly upon
connection when service registration had already occurred.
Paul, if you would agree, I would ask that you would verify the fix and
then contribute the test case code and I will add it to the test cases
for remote service testing. I'll be adding to these test cases as well
(as with the all test cases), and would appreciate any test cases that
people would be willing to write (for remoteservice or other APIs).
Scott
Scott Lewis wrote:
> Hi Paul,
>> Hi Guys,
>> ID serverID =
>> IContainer server =
>> args);
>> waitTime(2000);
>> yield no results.
>> something dumb?
>> either.
> Scott
>> Thanks in advance,
>> Paul
Current Time: Thu Apr 25 12:12:36 GMT 2024
Powered by FUDForum. Page generated in 0.04260 seconds
