Home » Archived » Service Oriented Architecture Tools Platform (STP) » HelloWorld template creation fails (my fault?)
HelloWorld template creation fails (my fault?) [message #608556] Fri, 18 January 2008 18:01 Go to next message
Originally posted by: a.piraino.centrica.it
--------------090002000809040009070104
Hello everyone,
I've installed on my linux box eclipse 3.3 and downloaded the necessary
modules for BPEL related developing.
Being a newbie of this technology, I started with a HelloWorld template
through the wizard "New BPEL process file" but failed to obtain a .bpel
file that eventually runs. Does it need more before starting? A WSDL
maybe? See console output attached.
So I've downloaded the bpel_examples.zip from the tutorial and succeded
in running the test_general.bpel file, connected to localhost:11000 but
found nothing I could find useful, besides the fact that I didn't find
the java classes created (if any). Do I have to run another command to
perform an export?
All in all I need to understand how to perform the following:
1) create a simple bpel files that loads a WSDL file
2) run the bpel file that the Eclipse plugin creates
3) finally generate the relevant Java classes
I know this is a generic question, but I'm sort of lost because I can't
understand how far my ignorance goes far and how soon the plugin's bugs
comes towards me.
Any help will be much appreciated.
Antonio
Content-Type: application/octet-stream;
name="HelloWorld.zip"
filename="HelloWorld.zip"
UEsDBBQAAAAIAAqXMjgmwBp8OQYAAMYrAAAOAAAASGVsbG9Xb3JsZC50eHTt WllzGjkQfudX
6GGrjKuS4fCRmIetsg0kTtkJZZxy3igx04CMGM1KGh//flvSDGDPcMUDjrf2 DUbq/vpW6zjr
tC5Jm3FokK/AubgVkgdePwJe+gIhSKpZOCQQDlkIJJJiKOnE87xS6cwQ3kga Kk61kA1SJd9O
r0kAEYQBhD4DRQZCko6jIb6YRAynMhFmacttFlJO7PeuiKUP+4RNIiG1Ih// npfsQQW8ePrb
bvOSXFiCBhkYa1RGYgKVuwkNK9F4qCp39J5WwOcsUlDxHoQcq4j6UK/cgNKV ykqE01iLj8OZ
RS2isY+QQy/h6ykdef36necLCd6dM7rHQg0StfPgUUOo0H7KYvRZGCAn/M0G nlXV66LOHL5q
HZ1zBqHu4NfSr27zmSQDEYcBMV+VP4IJJSx00gTCjydIlaGQQmgCHMwg2Zup eg3/xKj9HimP
ELJRqTw8PHgPBx6qVKlXq7XKr6vLrsVo7GeYmnjg8HjzFAFBgUC+JxjCFJpt BJJZZ2rDPaQT
WATvZiwDS0PAoJnsqyhqKBsZkqyKixVSEQYLbN9wfyBOAR56ibaOixxNVsvV SWf/zZNMQCk6
BLJpgFw5uizDtpUhGSYdKjWJ6BMXNPidKCxCXmetbQuc+mSVxMijl/DrYSXu YSXumUrcSypx
L63EvVkl7s1V4p6pxD1biRu+BKrhXIgxg3OKLke7vbUAai0LS9Br5BdKsluD BlgQVhs0N2Kk
rr4TjXI8tE0BhOkUvoAu2pRKS4TasTVnyhQZ52+higKNTfPj087csoBn7U/M mplx3ihZbpke
uaRV/ztobUO995x0WnWE2l2xfIXTN+VZfwdW/+9E0DurIDsNpgU8D/7cSpfx 6E4C1Uhgt8xr
74OyPAgRkT2OEiFuR3GfjBuGIpDOKed96o+XI4oQTRXznI3vS8QifZZ3QtZJ 8JbLm9lQLZ+e
6e5XTE9XzeXT0u5nTWZzcbkOhQnldectZW1PP03ehiAJZ+HYna68Klal4DB3 kItmuGfmtGj9
k4CcNMqwTY43NuKbxnsO/+WG2HpgO+BLxF2oeh7dN3pPuyDvmQ9TM+wqCfez R+euNnGmzEFe
wq6gY/Pb7kXbaHvmPs5QdyXFdPwi+ZEsEm8mkBI08ro/TjtrSECDANyh5rkI wC/QJ20hJ9TG
g+W8A+jpeOKAnePior8A85mjH1Xgaoieztil3bcvy5qO2KEgU8+YGjovQ5MF 4Z42MWF7FmIp
BtSfX1CIFkSPYP76ExcCpUkffBorIEzjqgrKMBrReyCURLGMhILfgkvXolfA mnpIkuxvEHM3
etEm8x9N7xrL0Flc4oLJJOZEP9YkFM/GVAQ+GzAItsJzffMsW29eYSisAgsv kj4S0yt4jxOO
UWWW0F5vunyapdSM9lwn4fUy7cdL1j+/X1x1LltXre83rWYDS0/Mra4TOjYK RITDPXD8G0XG
lgMpJtmexmhapFDF6OsuZ4pW2HF9hcaJWNlrfM7JQbraKjKgjIPL8WQSYOc/ oLivIa3Otb3g
f9b+7fk2Aje5VMzpiNKkSUFN0BpRYgkNkzCz9Er7Anf/aMUxubFhO76xAC33 XiRtaqZb3zcS
x/QzBWGXSq3r6x/XuKefur4fM6zzz5/IuJC0gir7HqVUwh1Ln8OENEH5kkVG yEapbB+b5L1f
+WACBofqh/ukXP1Q+1Ddf5vomxNcI6BqlNZfWl1VBWkfFHlGvZnbWo8+OCuQ d2AFQvUGLcUy
vb2pmHP7s/KLOea5UeOkerR1YJWL/OnTwZaQpfCxFuSCHh4e1gpFHYLdyuaD HX3+XDSYi9kF
yh0f14vGS57W5eOdHB9uikcj5p0hVMK3TX1k9+S5ky9X0tMhrG5mptO4nENk hfi8yp9R3OfM
N7iJLJht4z6E/sjo5CA9GYfpQlLOG7dQ9ZOTgrBSqy6Eqh3sDqq+pALEbOY6 TmMk90U4YEPv
0v45t3+awGGI7ktmlHPHLNZBNSdgAujHw/mIRO3mWcTuYDCPezrkCsrx8faY H1dzUvkFczRW
03z5edHhMRrYs6v2aRg4ruXngy5680JqBdu/Phm/5nGr1ao5BcDqPOV2J/rK xgrmvGGT/LT0
RxgJyavbpIhiW2yWKY29xb9QSwECFAAUAAAACAAKlzI4JsAafDkGAADGKwAA DgAAAAAAAAAB
ACAAAAAAAAAASGVsbG9Xb3JsZC50eHRQSwUGAAAAAAEAAQA8AAAAZQYAAAAA
--------------090002000809040009070104--
Re: HelloWorld template creation fails (my fault?) [message #610562 is a reply to message #608556] Wed, 23 January 2008 15:40 Go to previous message
Antony Miguel is currently offline Antony MiguelFriend
Member
Hi Antonio,
B2J has not been tested with the 'New BPEL process file' wizard. Rather
its testing is based around the tutorial test files.
In general there are some important differences between B2J and a
typical BPEL engine which may cause compatibility issues when running
BPEL not destined for B2J inside B2J.
The details of these differences are described in the B2J tutorial under
"BPEL servers and the B2J reference BPEL engine". The BPEL tutorial can
be found at the following link:
http://www.eclipse.org/stp/b2j/docs/tutorials/wsbpel/wsbpel_ tut.php
thanks
Antony
Antonio Piraino wrote:
> Hello everyone,
> perform an export?
> comes towards me.
> Antonio
Previous Topic:Re: HelloWorld template creation fails (my fault?)
Next Topic:STP EID & IM integration plans
Current Time: Thu May 28 22:53:54 GMT 2020
Powered by FUDForum. Page generated in 0.01544 seconds
