Re: add the aspectj nature in my plugin [message #61566 is a reply to message #61510] |
Wed, 01 February 2006 11:15 |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Luca,
So you want to be able to programmatically convert a Java project to an
AspectJ project? It sounds like the
internal AJDTUtils.addAspectJNature(project) method is the one you want. I
suggest you try calling this, and if it is what you want then raise a
bugzilla report requesting public API for this. Our approach is to
start with everything as internal API, and then add things to
the public API as required. This method sounds like a good candidate to
make public for AJDT 1.4.
Matt.
On Tue, 31 Jan 2006 17:56:51 +0000, Luca Zenti wrote:
> Hi, I'm developing an eclipse plugin that doesn't use aspectj on its own
> classes but needs to weave the classes of the projects it is applied to
> when deployed (I have a custom nature). All the aspects I need are
> contained in the plugin itself.
> The first thing I tried is to add the aspectj nature to the project when I
> add my own one but I have to use an internal ajdt class (AspectJUtils) and
> it does the job asynchronously, hence I can't do the rest of the job in
> the same action.
> Copy and paste the code from the internal classes of ajdt doesn't appear
> to be a good idea, so any suggestion?
> What exactly is a "aspectj-enabled plugin"? Doesn't seem to fit my problem
> from the docs, but I can surely miss something.
> Thanks a lot in advance.
> Luca.
Re: add the aspectj nature in my plugin [message #592061 is a reply to message #61510] |
Hi Luca,
Matt.
> the same action.
> Luca.
FUDForum. Page generated in 0.02408 seconds
