Home » Archived » Visual Editor (VE) » Painting an SWT Table
Painting an SWT Table [message #607890] Mon, 06 June 2005 13:14
Originally posted by: tcnesham.email.uophx.edu
------=_NextPart_000_0068_01C56A91.40813960
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I dropped a table into the VE shell painter and that worked correctly. =
But after I added a new constructor and added some methods the table =
object appears below the shell frame. I want to add some code to the =
class that contains the table, is there a preferred way to do this? =
Should I extend the table/class and add my code there? Is there a bug? =
Perhaps I am mixing the wrong versions? I should mention that I have =
MyEclipse installed. Are these the correct versions to match together?
Eclipse Java Development Tools Version: 3.0.2
Java EMF Model Version: 1.0.2
Visual Editor Version: 1.0.2=20
Eclipse Graphical Editing Framework 3.0.1
EMF Service Data Objects (SDO) Version: 2.0.1
Eclipse Modeling Framework (EMF) Version: 2.0.1
TIA,
Tim
--=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1491" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I dropped a table into the VE shell =
painter and=20
that worked correctly.&nbsp; But after I added a new constructor and =
added some=20
methods the table object appears below the shell frame.&nbsp;I want to =
add some=20
code to the class that contains the table, is there a preferred way to =
do this?=20
Should I extend the table/class and add my code there?&nbsp; Is there a =
bug?=20
Perhaps I am mixing the wrong versions?&nbsp; I should mention that I =
have=20
MyEclipse installed.&nbsp; Are these the correct versions to match=20
together?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Eclipse Java Development Tools Version: =
3.0.2<BR>Java EMF Model Version: 1.0.2<BR>Visual Editor Version: 1.0.2=20
<BR>Eclipse Graphical Editing Framework 3.0.1<BR>EMF Service Data =
Objects (SDO)=20
Version: 2.0.1<BR>Eclipse Modeling Framework (EMF) Version:=20
2.0.1<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>TIA,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Tim</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><BR>-- <BR></FONT></DIV></BODY></HTML>
------=_NextPart_000_0068_01C56A91.40813960--
Previous Topic:Extending VE to support thinlets
Next Topic:Painting an SWT Table
Current Time: Thu Jul 17 19:12:19 EDT 2025
Powered by FUDForum. Page generated in 0.28833 seconds
