Adding JRadioButton to ButtonGroup generates improper code [message #607762] |
Sat, 14 May 2005 14:40 |
JDK1.5
Eclipse 3.1M6
EMF build I200504141117
GEF Build 3.1M6
VE-runtime-1.1M1
When a JRadioButton is added to a button group, VE generates both of
these import statements:
import javax.swing.JToggleButton$ToggleButtonModel;
import javax.swing.JToggleButton.ToggleButtonModel;
Note the first has a "$".
VE also adds code to the getJRadioButton() method, resulting in:
private JRadioButton getJRadioButton0() {
if (jRadioButton == null) {
JToggleButton.ToggleButtonModel toggleButtonModel3 = new
JToggleButton.ToggleButtonModel();
toggleButtonModel3.setGroup(getButtonGroup());
jRadioButton = new JRadioButton();
jRadioButton.setModel(toggleButtonModel3);
return jRadioButton;
Fix the imports and Save.
In the design view, VE now complains of an Illegal Argument Exception
(IWAV0177E expression too complicated) on toggleButtonModel3 - the
exception is in the tool tip, not in the log files.
Manually changing the method code to:
jRadioButton.getModel().setGroup(getButtonGroup());
eliminates the exception.
Also, is there a reason VE does not automatically generate the manually
revised version of the method, leveraging getModel(), given that
creating the new JRadioButton creates the proper model by default.
FUDForum. Page generated in 0.23910 seconds
