[CommonNavigator] Programmatically / Automatically refresh non-resource content [message #606140] |
Mon, 21 June 2010 12:20 |
Xavier Coulon Messages: 58 Registered: July 2009 |
Member |
I'm working on a plugin that's aimed at helping Web developpers building RESTFul applications using the JAX-RS spec, within Eclipse ;)
For now, I have a builder that is configured with a facet and that builds an internal JAX-RS "registry", which is stored in the Project's session properties. This "registry" is based on annotations found on classes of the project, so it is not bound to a particular resource.
To display this registry, I added a custom navigatorContent that is associated to the "Project Explorer" viewer.
This works almost fine : when I clean the project, a "full build" is triggered, and the "registry" is initialized and stored in the project. But on the UI side, I cannot programmatically refresh the viewer.
I tried to add a my ITreeContentProvider impl as an IResourceChangeListener for POST_BUILD event as below:
public ContentProvider() {
IWorkspace workspace = ResourcesPlugin.getWorkspace();
workspace.addResourceChangeListener(this, IResourceChangeEvent.POST_BUILD);
, so that when the build is done, I can trigger a viewer.refresh() :
public void resourceChanged(IResourceChangeEvent event) {
((TreeViewer)viewer).refresh();
But this approach fails with a SWTException :
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:355)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:521)
at org.eclipse.jface.viewers.AbstractTreeViewer.getTreePathFrom Item(AbstractTreeViewer.java:2866)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalGetWidg etToSelect(AbstractTreeViewer.java:1679)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalExpand( AbstractTreeViewer.java:1574)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToW idget(AbstractTreeViewer.java:2463)
at org.eclipse.ui.navigator.CommonViewer.setSelectionToWidget(C ommonViewer.java:451)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToW idget(AbstractTreeViewer.java:2900)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1399)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:402)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1353)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1482)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:548)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.j ava:358)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.j ava:515)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1414)
at org.bytesparadise.tools.jaxrs.ui.cnf.ContentProvider.resourc eChanged(ContentProvider.java:103)
at org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastBuild Event(Workspace.java:297)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
How can I automatically/programmatically refresh the navigator content, since the content is not bound to a particular resource ?
Thank you in advance
Xavier
FUDForum. Page generated in 0.02809 seconds
