Re: OrderedSet::flatten() [message #61312 is a reply to message #61265] |
Sun, 24 August 2008 14:22 |
Originally posted by: cdamus.zeligsoft.com
Hi, Stefan,
The flatten() operation *is* defined by OCL for the OrderedSet type:
it's inherited from Set, which is the supertype of OrderedSet. Because
Set's definition of flatten() returns a Set, naturally it would do the
same when applied to an OrderedSet.
Several other operations are inherited by OrderedSet, too.
Christian
Stefan Schulze wrote:
> Hi...
> according to the OCL specification the operation flatten() isn't defined for
> type OrderedSet. (Probably the simply forgot it? It's defined for Set,
> Sequence and Bag, too.)
> In your implementation (at least in v1.1.2) this operation is defined as
> OrderedSet::flatten():Set. I think you decided to implement flatten() for
> OrderedSets because it's simply logical. But is it intended to return an Set
> instead of an OrderedSet? Sequence::flatten() returns an Sequence, too.
> Stefan
Re: OrderedSet::flatten() [message #61428 is a reply to message #61383] |
Sun, 24 August 2008 19:50 |
Hi, Stefan,
No, there is no relationship between Bag and Sequence.
The relationship between OrderedSet and Set is indicated only by the one
statement that you quoted. This is one reason why I am working with the
RTF to publish CMOF models of the abstract syntax and the standard
library as formal artifacts in conjuction with the spec.
Christian
> "Christian W. Damus" <cdamus@zeligsoft.com> schrieb im Newsbeitrag
> news:g8rqqd$fk6$1@build.eclipse.org...
>> The flatten() operation *is* defined by OCL for the OrderedSet type: it's
>> inherited from Set, which is the supertype of OrderedSet. Because Set's
>> definition of flatten() returns a Set, naturally it would do the same when
> I expected that OrderedSet inherits Set, but I only found the diagram at
> p.172 where OrderedSetType and SetType only extends CollectionType. Because
> of this I understood "The OrderedSet is a Set" (p.145) as "The OrderedSet is
> a set" (not referring to the class but to the mathematic term).
> I'd expect Sequence extending Bag, too, but there I couldn't found anything
> ("A sequence is a collection" p.145)
> Stefan
Re: OrderedSet::flatten() [message #61476 is a reply to message #61452] |
Tue, 26 August 2008 13:04 |
Hi, Stefan,
Right, the metaclasses defining the Set and OrderedSet types are peers.
In general, there need not be a similar inheritance structure in
metaclasses as in their instances.
I have to ask ... why are you working on an OCL implementation that is
not the MDT OCL component? :-D
cW
> news:g8se2c$5d7$1@build.eclipse.org...
>> The relationship [generalization] between OrderedSet and Set is indicated
>> only by the one statement that you quoted.
> I'm currently working on a different part of my stuff, but accidentally I
> came across the OrderedSetType. I think in the implementation OrderedSetType
> doesn't inherit SetType but only CollectionType. I'm not really familiar
> with these ...Type-classes, so I'm not sure whether I missed something.
> It doesn't have an effect at the moment, because all the specified methods
> are either assigned to Collection or to OrderedSet and Set seperately. I
> only noticed this because I'm working on a executable OCL implementation and
> it is related to assigning OrderedSets to Set-variables.
> Stefan
Re: OrderedSet::flatten() [message #61523 is a reply to message #61499] |
Tue, 26 August 2008 14:40 |
Hi, Stefan,
I see. That sounds like the kind of extension to the OCL semantics that
you can find in the OMG's MOF QVT language(s). There's a good deal of
QVT activity in the Eclipse M2M project, if you're interested
participating in that. Although, the small increment of assignment
semantics and object construction would be a practical addition to the
MDT OCL component, for the purpose of using it in specifying behaviours
in EMF- and UML2-based metamodels.
If you would be interested in potentially contributing your work to
Eclipse, I'd be happy to work with you on that.
Christian
> Hi Christian,
> I need some support for (mainly) assignment, variable declaration and
> object-instanciation. Because of this I wrote a XOCL-component which uses
> the MDT OCL component for the plain OCL stuff.
> But if anybody is interested in this XOCL-component, I'd give it for free
> purpose.
> Stefan
> news:g90v0p$9m2$1@build.eclipse.org...
>> Hi, Stefan,
>> Right, the metaclasses defining the Set and OrderedSet types are peers. In
>> general, there need not be a similar inheritance structure in metaclasses
>> I have to ask ... why are you working on an OCL implementation that is not
FUDForum. Page generated in 0.04299 seconds
