Home » Archived » Eclipse Communications Framework (ECF) » ScribbleShare white board Plugin
ScribbleShare white board Plugin [message #605278] Fri, 30 June 2006 01:15 Go to next message
I downloaded ECF0.8 But after downloading I have not got
org.eclipse.ecf.tutorial in plugins. I tried to download from the CVS also
but there it was failed. I need this plugin so as to integrate white
board.
Please suggest me possible solution.
Thanks in advance
Digvijay S Rana
Re: ScribbleShare white board Plugin [message #605293 is a reply to message #605278] Sun, 02 July 2006 23:42 Go to previous message
To get via anonymous CVS either
a) follow instructions here: http://www.eclipse.org/ecf/resources.html
(the project set file below is also on this page)
b) Save the following to local file and in Eclipse File->Import ->Team
project set:
<psf version="2.0">
<!-- Required Eclipse CVS repository connections: -->
<!-- :pserver:anonymous@dev.eclipse.org:/home/technology -->
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf,org.eclipse.ecf "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.discovery,org.eclipse.ecf.discover y "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.doc,org.eclipse.ecf.doc "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.call,org.eclipse.ecf.call "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.clients,org.eclipse.ecf.ex ample.clients "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.collab,org.eclipse.ecf.exa mple.collab "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf..example.collab.editor,org.eclipse .ecf.example.collab.editor "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.hello,org.eclipse.ecf.exam ple.hello "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.provider,org.eclipse.ecf.e xample.provider "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.fileshare,org.eclipse.ecf.fileshar e "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.datashare,org.eclipse.ecf.datashar e "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.provider.fileshare,org.eclipse.ecf .provider.fileshare "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.provider.datashare,org.eclipse.ecf .provider.datashare "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.presence,org.eclipse.ecf.presence "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.provider,org.eclipse.ecf.provider "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.provider.jmdns,org.eclipse.ecf.pro vider.jmdns "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.provider.xmpp,org.eclipse.ecf.prov ider.xmpp "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.jivesoftware.smack,org.jivesoftware.smack "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/tests/org.eclipse.ecf.test,org.eclipse.ecf.test "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/tests/org.eclipse.ecf.test.datashare,org.eclipse.ecf.test. datashare "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.ui,org.eclipse.ecf.ui "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.library,org.eclipse.ecf.ex ample.library "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.sdo.editor,org.eclipse.ecf .example.sdo.editor "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.example.sdo.gefeditor,org.eclipse. ecf.example.sdo.gefeditor "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.sdo,org.eclipse.ecf.sdo "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/features/org.eclipse.ecf.server-feature,org.eclipse.ecf.se rver-feature "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.server,org.eclipse.ecf.server "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/technology,org.eclipse.ec f/plugins/org.eclipse.ecf.tutorial,org.eclipse.ecf.tutorial "/>
</provider>
</psf>
Digvijay S Rana wrote:
> Hi
> also but there it was failed. I need this plugin so as to integrate
> white board.
> Thanks in advance
> Digvijay S Rana
Previous Topic:Example_Shared_Text_Editor
Next Topic:Is there any built-in API in Eclipse to support Radar Views?
Current Time: Fri Jun 20 11:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
