Enabling and Disabling Paste Icons [message #604331] |
Fri, 22 January 2010 16:49 |
Dhinesh Messages: 2 Registered: July 2009 |
Hello Folks,
I have developed a plug-in for doing copy-Paste feature to copy and paste a particular Object. It is a seperate plug-in. Both Copy and Paste are associated with a View that is contributed by a different plug-in.
So, in short to mention the Plug-in details.
Copy/Paste contributed by com.a.b --> Seperate.
View is provided by com.c.d ->> Seperate
I have used Eclipse copy/paste actions..i.e org.eclipse.ui.copyaction and org.eclipse.ui.pasteaction. I have contributed a pop-up menu Extensions mentioning the action IDs.
Basically Copy/paste works fine,but I want to enable and disable the actions based on the Clipboard contents.
I have written the code in selectionChanged() event of the action class. It's getting fired only when this plug-in is loaded. Until then, the paste action is enabled eventhough there is no relevant data to be pasted.
Now I want to disable it when the Eclipse is launced.
Could anyone of you pls help me with this problem.
Thanks in Advance,
Dhinesh.M
FUDForum. Page generated in 0.02622 seconds
