Headless PDE build fails for platform specific plugins [message #603715] |
Mon, 30 November 2009 18:51 |
Ash Maurya Messages: 23 Registered: July 2009 Location: Austin, TX |
Hi -
When running a headless PDE build against my .product, I'm getting the following errors during the generateScript task:
[java] generateScript:
[java] Property "outputUpdateJars" has not been set
[java] Property "archivesFormat" has not been set
[java] Property "product" has not been set
[java] Property "forceContextQualifier" has not been set
[java] Property "significantVersionDigits" has not been set
[java] Property "generatedVersionLength" has not been set
[java] Property "platformProperties" has not been set
[java] Property "flattenDependencies" has not been set
[java] Property "parallelCompilation" has not been set
[java] Property "parallelThreadCount" has not been set
[java] Property "parallelThreadsPerProcessor" has not been set
[java] Property "p2.context.repos" has not been set
[java] [eclipse.buildScript] An error occurred while generating manifest for /tmp/pluginbuilder/cloudfire-build/plugins/com.wiredreach.jm ab.searchprovider.
[java] [eclipse.buildScript] Error parsing plugin manifest. Missing attribute "id" in element "plugin".
The com.wiredreach.jmab.searchprovider plugin is defined in feature.xml as:
<plugin
id="com.wiredreach.jmab.searchprovider"
os="macosx"
ws="cocoa"
arch="x86"
download-size="0"
install-size="0"
version="0.0.0"/>
If I take out the os/ws/arch lines, the errors go away but I obviously end up with a platform specific plug-in that I want filtered out.
Just for background, this is an old script I had working in Eclipse 3.3 that I am trying to migrate to 3.5. Am I missing something obvious?
Ash
Founder, WiredReach (makers of BoxCloud and CloudFire)
blog: http://www.ashmaurya.com
Re: Headless PDE build fails for platform specific plugins [message #604312 is a reply to message #603715] |
Thu, 21 January 2010 17:09 |
Giuseppe Montalto Messages: 18 Registered: July 2009 |
Hi all!
I'm experiencing a similar problem...
My sources are correctly built but, when it comes to packaging, I get a message in the log stating that:
Property "p2.gathering" has not been set
Condition false; not setting p2.publish.parts
and I end up with an update site, instead of a product.
that's strange because, along with many other items, I do set p2.gathering=true in my build.properties file and, at the beginning of the log, I can see: [property ]Loading /correct/path/to/my/build.properties and also, a few lines below, Setting project property: p2.gathering -> true
...any hint?
thanks in advance
FUDForum. Page generated in 0.03059 seconds
