XML schema "fixed" attribute and static final fields [message #603421] |
Tue, 11 November 2008 19:01 |
John T.E. Timm Messages: 161 Registered: July 2009 |
I am having some issues with EMF 2.4 generating static final fields that
correspond to the "fixed" attribute in the schema definition. For example,
using this snippet my from XML Schema definition:
<xs:attribute name="classCode" type="RoleClass" use="optional"
default="BIRTHPL"/>
Under EMF 2.2, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT =
CDAR2Factory.eINSTANCE.createFromString(CDAR2Package.getRole Class(),
"BIRTHPL");
protected Object classCode = CLASS_CODE_DEFAULT;
Under EMF 2.4, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT; // TODO: the default
literal value "BIRTHPL" is not valid.
which obviously fails compilation due to unassigned static final field.
What has changed between the two EMF versions that would cause this issue?
Is there a workaround?
JT
FUDForum. Page generated in 0.01675 seconds
