Home » Archived » XML Schema Definition (XSD) » Can't get XSD graphical editor working...
Can't get XSD graphical editor working... [message #602994] |
Fri, 25 April 2008 19:31 |
Mike Messages: 49 Registered: July 2009 |
Member |
Hi all,
I recently downloaded and installed the EMF along with anything and
everything I thought I would need to enable graphical (GUI-driven) editing
of XML schema (XSD) and XML files.
Unfortunately, I cannot seem to get the graphical design editor tab
("Design") to show up in the list of tabs along the bottom of the file
window currently being edited. I'm expecting this tab to be there based
on the following tutorial:
http://wiki.eclipse.org/index.php/Introduction_to_the_XSD_Ed itor
I only have the following tabs visible when editing an XSD file: "Source",
"Semantics", "Syntax".
Can some one show me how or tell me what to do to get the graphical editor
to work for XSD files?
Mike
FYI - Here's my config and what I installed wrt EMF:
Eclipse Version: 3.3.0
Build id: I20070621-1340
(Sorry for the cut-n-paste below. Don't know any other easier way to
provide the information)
Apr 22, 2008 11:28:23 AM
Date / Time Target Action Status
Apr 22, 2008 11:28:01 AM
org.eclipse.emf.codegen.ecore.ui_2.3.1.v200802051830 feature-install
success
Apr 22, 2008 11:28:14 AM
org.eclipse.emf.codegen.ecore.ui_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.codegen.ecore_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:16 AM
org.eclipse.emf.codegen.ecore_2.3.2.v200802051830 feature-enable success
Apr 22, 2008 11:28:16 AM org.eclipse.emf.codegen.ui_2.3.1.v200802051830
feature-install success
Apr 22, 2008 11:28:17 AM org.eclipse.emf.codegen.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:17 AM org.eclipse.emf.codegen_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.codegen_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.common.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.common_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.converter_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.doc_2.3.2.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore.edit_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore.editor_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore_2.3.2.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.edit.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.edit_2.3.2.v200802051830
org.eclipse.emf.mapping.ecore.editor_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.mapping.ecore.editor_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.mapping.ecore_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.mapping.ecore_2.3.1.v200802051830 feature-enable success
Apr 22, 2008 11:28:18 AM org.eclipse.emf.mapping.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.mapping_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.sdk_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf.source_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf.sdk_2.3.2.v200802051830
org.eclipse.emf.ecore.sdo.doc_2.3.2.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.doc_2.3.2.v200802051830 feature-enable success
org.eclipse.emf.ecore.sdo.edit_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.edit_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.editor_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.editor_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.sdk_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:21 AM org.eclipse.emf.ecore.sdo_2.3.1.v200802051830
org.eclipse.emf.ecore.sdo.source_2.3.2.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.sdk_2.3.2.v200802051830 feature-enable success
org.eclipse.emf.ecore.sdo.source_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:21 AM org.eclipse.xsd.doc_2.3.2.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.doc_2.3.2.v200802051830
org.eclipse.xsd.ecore.converter_2.3.2.v200802051830 feature-install
success
org.eclipse.xsd.ecore.converter_2.3.2.v200802051830 feature-enable
success
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.edit_2.3.0.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.editor_2.3.0.v200802051830
org.eclipse.xsd.mapping.editor_2.3.0.v200802051830 feature-install
success
org.eclipse.xsd.mapping.editor_2.3.0.v200802051830 feature-enable
success
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.mapping_2.3.0.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd.source_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
org.eclipse.emf.examples.source_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.examples.source_2.3.1.v200802051830 feature-enable
success
Apr 22, 2008 11:28:23 AM org.eclipse.emf.examples_2.3.1.v200802051830
Current Time: Tue Apr 23 16:53:31 GMT 2024
Powered by FUDForum. Page generated in 0.02867 seconds
