Home » Archived » XML Schema Definition (XSD) » Changing XSDSchema / Clone
Changing XSDSchema / Clone [message #602975] |
Mon, 21 April 2008 21:38 |
Originally posted by: spotthoff.gmx.de
I am trying to change a XSDSchema Object. In my use case I want to change
just a copy of this schema not the original one.
Everything seems to work fine but the cloning does not clone the complexe
types as it seems. In my understanding both lines below should have the
same result concerning the code at the end.
All complexe Types are null. Why? Where is my fault?
1. change.test((XSDSchema)schema.cloneConcreteComponent(true, false));
2. change.test(schema);
But the result of statement 1 is:
bla 2: SKU - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@1a99561
(element: null) (name: SKU, targetNamespace: null) (variety: <unset>,
final: null, lexicalFinal: null, validFacets: null)
bla 2: USState - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@8e32e7
(element: null) (name: USState, targetNamespace: null) (variety: <unset>,
and of statement 2:
bla 1: herstellerorg.eclipse.xsd.impl.XSDParticleImpl@1a99561 (element:
[xs:all: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 1: Itemsorg.eclipse.xsd.impl.XSDParticleImpl@8e32e7 (element:
[xs:sequence: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 1: partsorg.eclipse.xsd.impl.XSDParticleImpl@1b000e7 (element:
bla 1: PurchaseOrderTypeorg.eclipse.xsd.impl.XSDParticleImpl@b76fa
(element: [xs:sequence: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 2: SKU - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@b01d43
(element: [xs:simpleType: null]) (name: SKU, targetNamespace: null)
(variety: atomic, final: [], lexicalFinal: null, validFacets: [length,
minLength, maxLength, pattern, enumeration, whiteSpace])
bla 1: USAddressorg.eclipse.xsd.impl.XSDParticleImpl@513cf0 (element:
bla 2: USState - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@177b3cd
(element: [xs:simpleType: null]) (name: USState, targetNamespace: null)
#### Test Code:
private void test(XSDSchema s){
XSDTypeDefinition type = null;
EList <XSDTypeDefinition> types = s.getTypeDefinitions();
for(Iterator<XSDTypeDefinition> it = types.iterator();
it.hasNext();){
XSDTypeDefinition typ = it.next();
if(typ.getComplexType()!= null){
XSDParticle t = typ.getComplexType();
System.out.println("bla1: " + typ.getName() + t);
if(typ.getSimpleType()!= null){
System.out.println("bla2: " + typ.getName() +
typ.getSimpleType());
Current Time: Thu Apr 25 16:56:29 GMT 2024
Powered by FUDForum. Page generated in 0.02838 seconds
