Home » Modeling » OCL » Sequence.subSequence with invalid arguments
Sequence.subSequence with invalid arguments [message #60961] |
Wed, 20 August 2008 20:18 |
Originally posted by: artem.borland.com
Sequence{'single-element'}->subSequence(2, 1) evaluates to null, not
invalid as one might expect. Null, as a legal value, might get mixed with
other values being collected along with the incorrect subSequence
expression, and tracing such problem might be quite tricky. I wonder if
OCL spec mandates null for such cases (I didn't find anything, however)
or if there's reason to have null.
As a side note, it looks odd to me one can't use subSequence to end up
with empty collection. Is there any design rationale behind that as well?
Re: Sequence.subSequence with invalid arguments [message #60985 is a reply to message #60961] |
Wed, 20 August 2008 21:01 |
Originally posted by: cdamus.zeligsoft.com
Hi, Artem,
I would expect invalid in the case of subSequence(2, 1) because that
violates a pre-condition constraint of the Sequence::subsequence()
operation. Please raise a bug for this.
Yes, it is odd that one cannot take an empty sub-sequence. That's a
consequence of the upper bound being inclusive, which was a deliberate
decision in the language design. I don't know that the consequence of
being unable to specify an empty range was intended, though. Certainly,
it couldn't be fixed by allowing a lower bound one greater than the
upper bound, which would just be two wrongs making something ugly (not
at all right).
OCL has the empty-sequence literal for these cases; I guess that'll have
to do.
Christian
Artem Tikhomirov wrote:
> Hello,
> with other values being collected along with the incorrect subSequence
Re: Sequence.subSequence with invalid arguments [message #61053 is a reply to message #60985] |
Wed, 20 August 2008 22:45 |
Radomil Dvorak Messages: 249 Registered: July 2009 |
Hi Christian,
It seems that subSequence(...) is not the only case where invalid would =
be =
a more
appropriate return value.
For instance, Sequence::at(Integer) operation if called with an index ou=
t =
of bounds
should give invalid rather then null IMO.
If not, it might appear that null element exists at that position.
Consequently, first(), last() operations seem affected too as
Sequence{}->first() =3D Sequence{}->including(null)->first()
might confuse things a bit.
However, the OMG spec says, "->first() element of an empty collection wi=
ll =
result in undefined.",
though in a bit strange place for this operation contract ;).
I can surely raise a bugzilla if you agree it's something to be fixed.
/Radek
On Wed, 20 Aug 2008 23:01:48 +0200, Christian W. Damus =
<cdamus@zeligsoft.com> wrote:
> Hi, Artem,
> I would expect invalid in the case of subSequence(2, 1) because that =
> violates a pre-condition constraint of the Sequence::subsequence() =
> Yes, it is odd that one cannot take an empty sub-sequence. That's a =
> consequence of the upper bound being inclusive, which was a deliberate=
> decision in the language design. I don't know that the consequence of=
> being unable to specify an empty range was intended, though. Certainl=
y, =
> it couldn't be fixed by allowing a lower bound one greater than the =
> upper bound, which would just be two wrongs making something ugly (not=
> at all right).
> OCL has the empty-sequence literal for these cases; I guess that'll ha=
ve =
> to do.
> Cheers,
> Christian
>> Hello,
>> Sequence{'single-element'}->subSequence(2, 1) evaluates to null, not=
>> invalid as one might expect. Null, as a legal value, might get mixed =
>> with other values being collected along with the incorrect subSequen=
ce =
>> expression, and tracing such problem might be quite tricky. I wonder =
if =
>> OCL spec mandates null for such cases (I didn't find anything, =
>> however) or if there's reason to have null.
>> As a side note, it looks odd to me one can't use subSequence to end =
up =
>> with empty collection. Is there any design rationale behind that as =
>> well?
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Sequence.subSequence with invalid arguments [message #61076 is a reply to message #61053] |
Wed, 20 August 2008 23:40 |
Hi, Radek,
Yes, I suspect that the terminology "undefined" in this case is a
throw-back to when "null" was called "OclUndefined." It doesn't help,
though, that "invalid" also responds true to oclIsUndefined(), in
addition to "null."
However, the fact that Sequence->first() returns null is consistent with
the fact that a null scalar is coerced to an empty set by the ->asSet()
operation. So, I don't like to mess with that.
Indexing out of bounds with at(Integer) is more clear-cut, though,
because the "at" operation has explicit constraints on the index. It's
too bad that the first() and last() operations are defined in terms of
at(), because that means that they must fail (with invalid) on empty
collections. A contradiction with some of the discussion in the spec.
So, gather the scenarios that you find problematic in a bug, and we can
resolve them in the 1.3/2.0 release. I hesitate to change the behaviour
of these operations in the maintenance branch; clients may have the
opposite expectations.
cW
Radek Dvorak wrote:
> Hi Christian,
> be a more
> out of bounds
> Sequence{}->first() = Sequence{}->including(null)->first()
> will result in undefined.",
> Regards,
> /Radek
-----8<-----
Re: Sequence.subSequence with invalid arguments [message #61194 is a reply to message #60985] |
Fri, 22 August 2008 12:56 |
Submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=244946
Empty sequence literal might not be a proper solution, e.g. when there's a
sub-sequence processing recursion, with the stop condition being empty
sequence. Given spec restriction stop condition needs to respect both
size() = 1 and size() = 0, which is not such a big deal, although tedious.
Christian W. Damus wrote:
> Hi, Artem,
> at all right).
> to do.
> Cheers,
> Christian
>> Hello,
Re: Sequence.subSequence with invalid arguments [message #61219 is a reply to message #61194] |
Fri, 22 August 2008 13:19 |
Thanks, Artem.
We're used to tedious, long-winded OCL expressions, aren't we? It's a
natural consequence of a small language. Just imagine: it could have
been Lisp!
> a sub-sequence processing recursion, with the stop condition being empty
-----8<-----
Current Time: Tue Apr 23 10:53:15 GMT 2024
Powered by FUDForum. Page generated in 0.04598 seconds
