EPF Composer - Activity Diagram Editor fail to open [message #599053] |
Wed, 13 January 2010 02:51 |
Can someone let me know why I am unable to open the activity diagram editor when I am working in my own Method Library? When I switch to EPF Practice library, I am able to open the same diagram editor, by right-clicking a delivery process or activity and selecting Open Activity Diagram.
What possibly could be the differences between EPF Practice library and my self-defined library?
Any log files I can check?
I am using Eclipse Process Framework Composer Version: 1.5.0.4 on Windows.
Thank you for your help.
regards,
yeuwen
Re: EPF Composer - Activity Diagram Editor fail to open [message #599060 is a reply to message #599053] |
Wed, 13 January 2010 05:43 |
An update to my problem posted earlier.
What is interesting is that when I import my Method Plug-in into EPL Practice 1.5.0.1 library, I am able to open the activity diagram editor in the process editor of my own process. My method plug-in has absolutely no dependencies on EPL Practice library.
Therefore, I can only conclude that something in the EPL Practice library is needed to open this Activity Diagram editor, a resource perhaps.
How can I isolate this dependency so that my method plug-in can exist independently of EPL Practice library?
Thanks.
yeuwen
Re: EPF Composer - Activity Diagram Editor fail to open [message #599067 is a reply to message #599060] |
Thu, 14 January 2010 01:46 |
Also, I found out that diagrams that belong to a plug-in is not exported together with the plug-in (at least in xml format) because when I import that plug-in into another library, a pop-up appears asking if I want to create a new diagram whenever I attempt to open the diagram editor.
Please help.
FUDForum. Page generated in 0.03378 seconds
