ClassGenException after upgrade to 1.6.1 [message #599030] |
Tue, 05 August 2008 14:27 |
Tom Duffey Messages: 2 Registered: July 2009 |
Not sure if this is Spring, AspectJ or both but...Upgraded to AspectJ
1.6.1 and Spring 2.5.6 nightly build 576 and now my project doesn't build.
Getting pages and pages of output during build but I think this is the
relevant part:
[iajc] -- (ClassGenException) Do not attempt to modify the index for
this constant instruction: aload_0[42](size1)
[iajc] Do not attempt to modify the index for this constant
[iajc] org.aspectj.apache.bcel.generic.ClassGenException: Do not
attempt to modify the index for this constant instruction:
aload_0[42](size1)
[iajc] at
org.aspectj.apache.bcel.generic.InstructionCLV.setIndex(Inst ructionCLV.java:19)
[iajc] at
org.aspectj.weaver.bcel.BcelClassWeaver.genInlineInstruction s(BcelClassWeaver.java:1949)
[iajc] at
org.aspectj.weaver.bcel.BcelClassWeaver.inlineMethod(BcelCla ssWeaver.java:1429)
[iajc] at
org.aspectj.weaver.bcel.BcelClassWeaver.inlineSelfConstructo rs(BcelClassWeaver.java:1352)
[iajc] at
org.aspectj.weaver.bcel.BcelClassWeaver.weave(BcelClassWeave r.java:502)
[iajc] at
org.aspectj.weaver.bcel.BcelClassWeaver.weave(BcelClassWeave r.java:105)
[iajc] at
org.aspectj.weaver.bcel.BcelWeaver.weave(BcelWeaver.java:166 9)
[iajc] at
org.aspectj.weaver.bcel.BcelWeaver.weaveWithoutDump(BcelWeav er.java:1620)
[iajc] at
org.aspectj.weaver.bcel.BcelWeaver.weaveAndNotify(BcelWeaver .java:1393)
[iajc] at
org.aspectj.weaver.bcel.BcelWeaver.weave(BcelWeaver.java:121 3)
[iajc] at
org.aspectj.ajdt.internal.compiler.AjPipeliningCompilerAdapt er.weaveQueuedEntries(AjPipeliningCompilerAdapter.java:454)
[iajc] at
org.aspectj.ajdt.internal.compiler.AjPipeliningCompilerAdapt er.queueForWeaving(AjPipeliningCompilerAdapter.java:391)
[iajc] at
org.aspectj.ajdt.internal.compiler.AjPipeliningCompilerAdapt er.afterProcessing(AjPipeliningCompilerAdapter.java:379)
[iajc] at
org.aspectj.ajdt.internal.compiler.CompilerAdapter.ajc$after $org_aspectj_ajdt_internal_compiler_CompilerAdapter$5$6b8551 84(CompilerAdapter.aj:98)
[iajc] at
org.aspectj.org.eclipse.jdt.internal.compiler.Compiler.proce ss(Compiler.java:641)
[iajc] at
org.aspectj.org.eclipse.jdt.internal.compiler.Compiler.compi le(Compiler.java:392)
[iajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.perfor mCompilation(AjBuildManager.java:995)
[iajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:269)
[iajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.batchB uild(AjBuildManager.java:184)
[iajc] at
org.aspectj.ajdt.ajc.AjdtCommand.doCommand(AjdtCommand.java: 112)
[iajc] at
org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :60)
[iajc] at org.aspectj.tools.ajc.Main.run(Main.java:382)
[iajc] at org.aspectj.tools.ajc.Main.runMain(Main.java:254)
[iajc] at
org.aspectj.tools.ant.taskdefs.AjcTask.executeInSameVM(AjcTa sk.java:1307)
[iajc] at
org.aspectj.tools.ant.taskdefs.AjcTask.execute(AjcTask.java: 1105)
[iajc] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[iajc] at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
[iajc] at
[iajc] at java.lang.reflect.Method.invoke(Method.java:597)
[iajc] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[iajc] at org.apache.tools.ant.Task.perform(Task.java:348)
[iajc] at org.apache.tools.ant.Target.execute(Target.java:357)
[iajc] at org.apache.tools.ant.Target.performTasks(Target.java:385)
[iajc] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
[iajc] at
org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[iajc] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[iajc] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
[iajc] at org.apache.tools.ant.Main.runBuild(Main.java:698)
[iajc] at org.apache.tools.ant.Main.startAnt(Main.java:199)
[iajc] at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
[iajc] at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
Reverting back to AspectJ 1.6.0 seems to fix the problem.
Tom
FUDForum. Page generated in 0.03271 seconds
