Home » Archived » Test and Performance Tools Platform (TPTP) » Integrated agent controller: Cannot find a way to disable secure connections
Integrated agent controller: Cannot find a way to disable secure connections [message #60447] Mon, 27 March 2006 17:24 Go to next message
Originally posted by: not-disclosed.undisclosed.com
I recently installed the TPTP manually to my Eclipse 3.1 install. When I
try to Profile a Java application, I get a dialog asking me for a
userid/password to local host (secure connection). Some of the sparse docs
that I've found say that I should disable security to be able to run this,
but for the life of me I cannot find how. IN any case, when I try typing
any userid/pwd combination, I get message
IWAT0112E The agent controller on host localhost is configured to use
security. The product you have does not support secure connections. If you
want to connect to localhost you will need to disable security of the
agent controller on localhost.
Can someone please help me figure out how to turn off this secure
connection feature?
Re: Integrated agent controller: Cannot find a way to disable secure connections [message #60467 is a reply to message #60447] Mon, 27 March 2006 19:57 Go to previous messageGo to next message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006D9E9C8525713E_=
Content-Type: text/plain; charset="US-ASCII"
Which driver are you using? I remember a fix going in for this about two
weeks ago. Security on IAC was enabled by default, which it shouldn't
have been. Try grabbing a newer driver.
I don't even think it makes sense to enable security for IAC, since it's
only used locally. So I think it was removed because I can't find
anything on IAC security in my preferences.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Which driver are you using? &nbsp;I
remember &nbsp;a fix going in for this about two weeks ago. &nbsp;Security
on IAC was enabled by default, which it shouldn't have been. &nbsp;Try
grabbing a newer driver. &nbsp;</font>
<br>
<br><font size=2 face="sans-serif">I don't even think it makes sense to
enable security for IAC, since it's only used locally. &nbsp;So I think
it was removed because I can't find anything on IAC security in my preferences.</font>
<br>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 006D9E9C8525713E_=--
Re: Integrated agent controller: Cannot find a way to disable secure connections [message #61573 is a reply to message #60467] Tue, 28 March 2006 19:44 Go to previous messageGo to next message
If you are referring to the specific TPTP agent controller plug-in
version, that is 4.1.0.1. Otherwise, what is a driver version in this
context?
Thanks for your help!
Jaime.
Re: Integrated agent controller: Cannot find a way to disable secure connections [message #61669 is a reply to message #61573] Tue, 28 March 2006 21:52 Go to previous messageGo to next message
--=_alternative 0078323B8525713F_=
Alright, this is really strange, security is not in the 4.1.0.1 driver. I
thought you were using a 4.2 development driver. Here are a few questions
I need you to answer before I can help you:
1) Are you sure you're using IAC to profile your application? Are you
running the RAServer process or RAService service?
2) Did you download the "New technology Agent Controller" or "Agent
Controller" or neither one?
3) Do you know if you have the IBM RAC installed on your computer? Check
your windows\system32 for the piagent.dll
Navid Mehregani
<br><font size=2 face="sans-serif">Alright, this is really strange, security
is not in the 4.1.0.1 driver. &nbsp;I thought you were using a 4.2 development
driver. &nbsp;Here are a few questions I need you to answer before I can
help you:</font>
<br>
<br><font size=2 face="sans-serif">1) Are you sure you're using IAC to
profile your application? Are you running the RAServer process or RAService
service?</font>
<br><font size=2 face="sans-serif">2) Did you download the &quot;New technology
Agent Controller&quot; or &quot;Agent Controller&quot; or neither one?</font>
<br><font size=2 face="sans-serif">3) Do you know if you have the IBM RAC
installed on your computer? &nbsp;Check your windows\system32 for the piagent.dll</font>
<br>
--=_alternative 0078323B8525713F_=--
Re: Integrated agent controller: Cannot find a way to disable secure connections [message #63156 is a reply to message #61669] Fri, 31 March 2006 18:27 Go to previous messageGo to next message
I do have piagent.dll in my c:\program files (i forgot that I had RAD in
my PC). What are my options then? I did download the agent controller but
did not install or start the remote service, so I assumed I was using the
IAC. Thoughts?
Thanks a lot. This is helpful.
Re: Integrated agent controller: Cannot find a way to disable secure connections [message #63948 is a reply to message #63156] Tue, 04 April 2006 15:25 Go to previous message
Originally posted by: undisclosed.undisclosed.com
Once I remove the installation of RAD (hence, the piagent.dll), the
Eclipse profiler started working. It would be interesting to find out how
RAD and Eclipse TPTP can co-exist.
THanks again!
Jaime.
Previous Topic:How to record full execution information?
Next Topic:Agent Controller on Linux
Current Time: Sun Sep 27 00:33:44 GMT 2020
Powered by FUDForum. Page generated in 0.02346 seconds
