get min or max occurs [message #60210] |
Thu, 28 April 2005 15:21 |
Originally posted by: aaudevart.genigraph.fr
I am trying to extract the min and max occurs but I don't know what
interface i need use to get the max and min occurence.
<xs:element name="child_name" type="xs:string" minOccurs="0"
maxOccurs="5"/>
Can somebody help me please?
Thanks.
Re: get min or max occurs [message #60234 is a reply to message #60210] |
Thu, 28 April 2005 15:31 |
Alex,
A local element declaration or element reference gives rise to both an
XSDParticle and an XSDElementDeclaration and you should look for the min
and max on the particle.
Alex wrote:
> maxOccurs="5"/>
> Thanks.
Re: get min or max occurs [message #60258 is a reply to message #60234] |
Thu, 28 April 2005 15:59 |
I find a method which return a XSDParticle :
XSDSimpleTypeDefinition aSimpleType
XSDParticle particle = aSimpleType.getComplexType();
but the particule is always null.
May be it isn't the right method.
Here is my xsd code:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified">
<xs:element name="persons">
<xs:complexType>
<xs:sequence>
<xs:element name="person" maxOccurs="unbounded">
<xs:complexType>
<xs:sequence>
<xs:element name="full_name" type="xs:string"/>
minOccurs="0" maxOccurs="5"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
Thanks.
Re: get min or max occurs [message #60280 is a reply to message #60258] |
Thu, 28 April 2005 16:33 |
Alex,
This method applied to a simple type definition will return null; a
simple type does not have complex content. When applied to a complex
type, it will return the particle, as long as the type doesn't have
empty content or simple content, in which cases there is no particle.
> <xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> Thanks.
Re: get min or max occurs [message #60304 is a reply to message #60280] |
Fri, 29 April 2005 07:29 |
In my case, I've got a simple type so how can i extract the min and max
occurs?
I understand that this : <xs:element name="full_name" type="xs:string"/>
is a simple type and this is a complex type : <xs:element name="full_name"
type="bobi"/>.
Is it exact?
Re: get min or max occurs [message #60327 is a reply to message #60304] |
Fri, 29 April 2005 11:13 |
Alex,
A simple type doesn't have min and max occurs. Both things you show
are element declarations. So I'm quite confused...
In your earlier example you had an element called "persons" with an
anonymous complex type, so given the element declaration for "persons"
you could do xsdElementDeclaration.getType().getComplexType() to get the
root particular of the element's type; you'll get null unless it is a
complex type with complex content. Walking this particle tree will get
you to the "person" element nested in that type.
Alex wrote:
> max occurs?
> type="xs:string"/> is a simple type and this is a complex type :
> <xs:element name="full_name" type="bobi"/>.
> Is it exact?
> Thanks
Re: get min or max occurs [message #60348 is a reply to message #60327] |
Mon, 02 May 2005 08:55 |
Two possibilities, may be i don't understand what you explain to me or it
isn't working!
So if i want to extract the cardinality of "item" which are 0 and 5.
<xs:element name="toto" type="Items"/>
<xs:complexType name="Items">
<xs:sequence>
<xs:element name="item" minOccurs="0" maxOccurs="5">
<xs:complexType>
<xs:sequence>
<xs:element name="productName" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:schema>
I do that :
aComplexType is a XSDComplexTypeDefinition
So :
XSDParticle particle = aComplexType.getComplexType();
int min = particle.getMinOccurs()
int max = particle.getMaxOccurs()
But the problem is that min and max are always equals to 1 and 1.
Thanks for your help
Re: get min or max occurs [message #60371 is a reply to message #60348] |
Mon, 02 May 2005 10:29 |
Alex,
You'll find the the top level particle of a complex type has a term that
is a sequence and that this sequence contains the particles you are
interested in. I.e., stop and think about how it would work if you have
two elements rather than just one in your complex type.
Alex wrote:
> it isn't working!
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> I do that :
> So :
Re: get min or max occurs [message #595214 is a reply to message #60210] |
Ed Merks Messages: 33140 Registered: July 2009 |
Alex,
Alex wrote:
> maxOccurs="5"/>
> Thanks.
Ed Merks
Re: get min or max occurs [message #595235 is a reply to message #60258] |
Alex,
> <xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> Thanks.
Ed Merks
Re: get min or max occurs [message #595259 is a reply to message #60304] |
Alex,
Alex wrote:
> max occurs?
> Is it exact?
> Thanks
Ed Merks
Re: get min or max occurs [message #595283 is a reply to message #60348] |
Alex,
Alex wrote:
> it isn't working!
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> I do that :
> So :
Ed Merks
FUDForum. Page generated in 0.04256 seconds
