Re: Web Tools integration in q4e [message #6702 is a reply to message #5350] |
Sun, 23 March 2008 07:05 |
Originally posted by: rinku.apache.org
The screencast link comes back with a 404.
Rahul
Abel Muiño wrote:
> We've just finished the infrastructure for integrating with other
> plug-ins for configuring maven projects.
> The first example of this integration is for maven projects with war
> packaging, which are configured with the Dynamic Web Project facets from
> Web Tools Project.
> It is still work in progress, but if you want to check it out, it can be
> installed from the q4e development update site:
> http://q4e.googlecode.com/svn/trunk/updatesite-dev/
> The current feature set includes:
> - Integration with the new project and project import wizards.
> * If you're packaging is war, the project should automatically be WTP
> enabled.
> - Filtering of deployed artifacts
> * Only artifacts with default scope or compile scope will be deployed to
> your testing server.
> Usual WTP features like hot deployment of modified java files and
> resources, debugging and so on are also working.
> There is an screencast available at http://tinyurl.com/ynqewf
> Yours,
> Abel Muiño.
Re: Web Tools integration in q4e [message #565277 is a reply to message #5350] |
Rahul
> Web Tools Project.
> enabled.
> Yours,
> Abel Muiño.
FUDForum. Page generated in 0.03576 seconds
