How to trace the runtime of methods? [message #594723] |
Tue, 12 September 2006 13:50 |
Originally posted by: formatzeh.gmx.de
Hello Newsgroup,
I want to trace the runtime of methods by using
System.currentTimeMillis(). So first I had a class variable which was
set in the before-advice and was subtracted in the after-advice and then
printed to the output-stream. But then I recognized when there are
nested calls to methods that the runtime of the outer method isn't
correct. Well it is correct because the class variable was set in the
last nested method. So the subtraction results a wrong value. So my idea
was to pass a Calendar-Object from before to after-advice. so that every
method-call has it's own Calendar-Object. But how do I realize this? Is
it possible in some way? Sorry for my bad English - my German is better ;)
greetz
Gilbert Mirenque
FUDForum. Page generated in 0.05963 seconds
