Home » Archived » Test and Performance Tools Platform (TPTP) » No new perspectives, views, or menu items after installing TPTP
No new perspectives, views, or menu items after installing TPTP [message #59973] Fri, 24 March 2006 16:43 Go to next message
Originally posted by: Griffin.Whidbey.Net
I just installed TPTP in my Eclipse 3.1.2.
Actually, I've installed it twice. I tried once via the
download/unzip method, and when that didn't seem to add anything to
Eclipse, I did the "Find and Install ..." method.
I still don't have any new perspectives, views, or menu items.
As far as I can tell, it just isn't there.
Any suggestions on what I might be doing wrong?
Re: No new perspectives, views, or menu items after installing TPTP [message #60019 is a reply to message #59973] Fri, 24 March 2006 17:25 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. SmithFriend
You gave us the Eclipse version... what version of TPTP? Which version
of EMF/XSD?? What platform?
Did you try running eclipse -clean?
Give me a little more, and we'll get you through it.
RDS
Re: No new perspectives, views, or menu items after installing TPTP [message #60043 is a reply to message #59973] Fri, 24 March 2006 18:19 Go to previous messageGo to next message
Lisa Davis is currently offline Lisa DavisFriend
Hi Griffin--
I had this same problem the other day and someone named Parveed was kind
enough to give me a work around solution. It's not too far below this
string and it's entitled "Missing 3 plugins". Take a look at what both
Parveen and Randy had to say about that, and why the update approach
doesn't completely work just yet.
Lisa
Re: No new perspectives, views, or menu items after installing TPTP [message #60066 is a reply to message #60019] Fri, 24 March 2006 19:03 Go to previous messageGo to next message
Lets see, running on MS Windows XP Pro SP 2
Eclipse 3.1.2
TPTP 4.1.0.1
I don't know what EMF/XSD stands for. (If it is a required package, I
missed it in the instructions.)
I tried "eclipse -clean", and it made no difference.
On Fri, 24 Mar 2006 09:25:27 -0800, "Randy D. Smith"
Re: No new perspectives, views, or menu items after installing TPTP [message #60090 is a reply to message #60066] Fri, 24 March 2006 19:12 Go to previous messageGo to next message
Daniel Dominguez is currently offline Daniel DominguezFriend
EMF and XSD are required.
You can get download links from the requirements sections of
http://www.eclipse.org/tptp/home/downloads/downloads.php
> Eclipse 3.1.2
> TPTP 4.1.0.1
Re: No new perspectives, views, or menu items after installing TPTP [message #60137 is a reply to message #60090] Fri, 24 March 2006 22:55 Go to previous message
Ok, I decided to start "clean".
Luckily I had made a backup of my Eclipse folder before attempting
this install.
I went to the page you gave, downloaded the EHP, XSD, TPTP, and Agent
Controller.
Installed all of them.
Nothing.
So I did an "Eclipse -clean".
NOW things are appearing in my Menus! Hallelujah!
On Fri, 24 Mar 2006 11:12:34 -0800, Daniel Dominguez
>> Eclipse 3.1.2
>> TPTP 4.1.0.1
Previous Topic:Agent Controller on Linux
Next Topic:Can .NET apps be tested with TPTP? <eom>
Current Time: Tue Sep 29 14:33:55 GMT 2020
Powered by FUDForum. Page generated in 0.03123 seconds
