Could not open the editor: Editor could not be initialized. [message #592167] |
Wed, 23 July 2008 01:04 |
konkeong Messages: 13 Registered: July 2009 |
Dear All,
Does anyone encountered this problem?
I am using Ganymede (3.4) on windows xp sp 3 with JDK 1.5.0_09.
The Data Tools Platform Connectivity is
1.6.0.v200805151245-7_70Dn-QXuj8_GoX7JfPiBEG.
When I open a file of extension "*.sql", it open in the "SQL File
Editor" but with the error message and stack trace below.
java.lang.NoClassDefFoundError
at javax.crypto.SecretKeyFactory.getInstance(DashoA12275)
at
org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.loadKey(DefaultCipherProvider.java:66)
at
org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.createDecryptionCipher(DefaultCipherProvider. java:48)
at
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:749)
at
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:489)
at
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:936)
at
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:135)
at
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfileByName(InternalProfileManager.java:210)
at
org.eclipse.datatools.connectivity.ProfileManager.getProfile ByName(ProfileManager.java:96)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getConnectionProfile(SQLEditorConnectionInfo.java:106)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getSharedConnection(SQLEditorConnectionInfo.java:229)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.isConnected(SQLEditorConnectionInfo.java:252)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getName(SQLEditorConnectionInfo.java:214)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.refreshCo nnectionStatus(SQLEditor.java:1726)
at
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.refreshConnectionStatus(SQLScrapbookEdito r.java:264)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.doSetInpu t(SQLEditor.java:919)
at
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.doSetInput(SQLScrapbookEditor.java:173)
at
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3025)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:446)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:354)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2483)
at
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3043)
at
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3070)
at
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.init(SQLE ditor.java:544)
at
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.init(SQLScrapbookEditor.java:128)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
at
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
at
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
konkeong
FUDForum. Page generated in 0.02746 seconds
