Newbie on Book [message #592000] |
Sun, 29 January 2006 22:08 |
J. Michael Dean, M.D. Messages: 218 Registered: July 2009 |
Working with the Colyer et al book and have loaded the examples, converted
the simple Java project to AspectJ. Am using Eclipse 3.1.1, AspectJ 1.5.,
JRE 5.0, Mac OSX 10.4.4. But the outline view is not doing anything
resembling the book - incremental compiling is turned on.
I tried turning off incremental compiling and then ended up with syntax
errors throughout the examples that were not reverse by turning it on again;
I actually had to remove the Aspect nature from the project and then convert
it again.
When I click on the PolicyImpl.java file, I get normal Outline view but when
I click on the PolicyChangeNotification.aj file I get nothing until I put in
the declare warning; however, the "matched by:" annotations do not appear.
There is no "+" next to the declare warning entry, which is the only thing
visible in the outline view.
FUDForum. Page generated in 0.02618 seconds
