Editors do not work [message #591405] |
Thu, 05 March 2009 11:14 |
No real name Messages: 33 Registered: July 2009 |
Member |
to give EPF a trial, I followed the installation instructions and than
successfully started it.
To get familiar with EPF, I wanted to follow some of the tutorials. But
after the first steps I encountered a problem I could not solve by now:
Every time I double click on an item in the library (e. g. a task), the
editor, which should display the item's details, reports a
NullPointerException and only shows the stack trace I appended to this post.
I tried to use the latest as well as the 1.5.0 release of EPF. Both show
the same behaviour no matter which Java version I use (1.5 and 1.6).
What can I do to solve this problem?
Thanks and regards,
Sebastian
at
org.eclipse.epf.authoring.ui.forms.DescriptionFormPage.dispo se(DescriptionFormPage.java:3033)
at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.ja va:420)
at
org.eclipse.epf.authoring.ui.editors.AbstractBaseFormEditor. dispose(AbstractBaseFormEditor.java:97)
at
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.dis pose(MethodElementEditor.java:1085)
at
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.add Pages(MethodElementEditor.java:1023)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at
org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:241)
at
org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:167)
at
org.eclipse.epf.authoring.ui.UIActionDispatcher$1.doubleClic k(UIActionDispatcher.java:128)
at
org.eclipse.epf.authoring.ui.UIActionDispatcher.handleDouble ClickEvent(UIActionDispatcher.java:292)
at
org.eclipse.epf.authoring.ui.views.LibraryView$7.doubleClick (LibraryView.java:554)
at
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1387)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
at
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdviso r(MainApplication.java:114)
at org.eclipse.epf.rcp.ui.MainApplication.start(MainApplication .java:80)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
FUDForum. Page generated in 0.01725 seconds
