Home » Archived » M2M (model-to-model transformation) » Stereotype property with defined type
Stereotype property with defined type [message #59682] Tue, 28 August 2007 17:26 Go to next message
Alexandre Torres is currently offline Alexandre TorresFriend
I'm experimenting with ATL and profiles.
I did create a profile with stereotype and added a property wich points to
one of uml meta-classes (Class metaclass for instance). This worked.
Now I want to define my own metaclass. A metaclass that has as properties
a Property element, and them bind it to my stereotype.
I create a class inside the profile definition named PropertyDependency,
and make the bind in the stereotype, something like:
<mystereo>
ClassDependency : Class
properties: PropertyDependency [0..*]
<Class> PropertyDependency
dependentProperty: Property [1]
kind: String
The point I'm stuck is, when I apply the sterotype, I can't create
PropertyDependency object in the UML editor. I don't think it's the proper
place to ask this, but I don't even know if this is the way to do that :)
Later my ATL will need to interpret this metamodel.
Thanks.
Re: Stereotype property with defined type [message #59706 is a reply to message #59682] Tue, 28 August 2007 18:01 Go to previous messageGo to next message
I did some homework and find this
http://dev.eclipse.org/newslists/news.eclipse.tools.uml2/msg 03997.html
Just had to set the property as COMPOSITE. It seems to have solved the
issue. going to test it now.
Very cool. Now the eclipse's "new child" show my new property.
Where is the best place to ask some tips to create profiles ? I would like
very much to attach an OCL expression to the property, so that it would
filter only properties of related classes in the stereotype.
Re: Stereotype property with defined type [message #59779 is a reply to message #59706] Wed, 29 August 2007 09:06 Go to previous message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Alexandre,
> Very cool. Now the eclipse's "new child" show my new property. Where is
The best place to ask questions about UML2 profiles and their creation
is the eclipse.modeling.mdt.uml2 newsgroup.
Of course, if your profiles (and UML2 models) are created and/or handled
by ATL transformations you're still invited to ask questions on this
newsgroup ;-)
> I would like very
> Thanks
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Previous Topic:[ATL] how to match rules only once
Next Topic:[QVT] Generic typed function
Current Time: Thu May 13 18:45:02 GMT 2021
Powered by FUDForum. Page generated in 0.02605 seconds
