Getting started with Ecore ODA Driver [message #590704] |
Tue, 01 April 2008 13:15 |
Hajo Eichler Messages: 25 Registered: July 2009 |
I checked out
org.eclipse.datatools.enablement.oda.ecore &
org.eclipse.datatools.enablement.oda.ecore.ui
and after some update of EMF Transaction, Query and Search I got them compiled and
could put the two plug-ins into my birt-report-designer-all-in-one-2_2_2.
After adding all depended plug-ins there, I finally get a new Data Source Type:
"Ecore ODA Data Source". Heureka ;-)
Now, I am somehow lost, since the data source asks me for 3 properties:
1) The ecore file: Here I put "platform:/resource/simpleTest/mindmap.ecore" Ok?
2) "Connection Profile Name" ... foobar should do it?
3) "Connection Profile Store URL" - can some explain the secrets behind?
Here I tried several thing: file, http and platform URL/Is.
But anytime I want to create a new Data Set, I get the attached exception.
So, it seems that I have some URI/URL Problem.
Can anyone help me out here?
When I got successfully through it, I would help to extend the current wiki page
(http://wiki.eclipse.org/Ecore_ODA_Driver-Proposal) with a small HowTo summarizing
my experience.
Thanks & Cheers,
Hajo
at org.eclipse.emf.common.util.URI.createURIWithCache(URI.java: 658)
at org.eclipse.emf.common.util.URI.createURI(URI.java:536)
at
org.eclipse.datatools.enablement.oda.ecore.impl.Connection.g etModel(Connection.java:67)
at
org.eclipse.datatools.enablement.oda.ecore.impl.Connection.o pen(Connection.java:55)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:235)
at
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:145)
at
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:134)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:121)
at
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:214)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:265)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:210)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:500)
at
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:161)
at
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:142)
at
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:141)
at
org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelp er.executeQuery(QueryExecutionHelper.java:113)
at
org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelp er.executeQuery(QueryExecutionHelper.java:92)
at
org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHel per.getRealMetaData(DataSetMetaDataHelper.java:147)
at
org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHel per.getDataSetMetaData(DataSetMetaDataHelper.java:101)
at
org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.getDataSetMetaData(DataRequestSessionImpl.java:168)
at
org.eclipse.birt.report.designer.data.ui.util.DataSetProvide r.populateAllOutputColumns(DataSetProvider.java:186)
at
org.eclipse.birt.report.designer.data.ui.util.DataSetProvide r.getCachedDataSetItemModel(DataSetProvider.java:793)
at
org.eclipse.birt.report.designer.data.ui.dataset.DataSetEdit or$ItemModelManager.start(DataSetEditor.java:879)
at
org.eclipse.birt.report.designer.data.ui.dataset.DataSetEdit or. <init>(DataSetEditor.java:224)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSetAction .editDataSet(NewDataSetAction.java:221)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSetAction .createNewDataSet(NewDataSetAction.java:161)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSetAction .run(NewDataSetAction.java:142)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
FUDForum. Page generated in 0.05432 seconds
