Error while trying to create service [message #589566] |
Mon, 02 July 2007 12:07 |
Jose Messages: 6 Registered: July 2009 |
Hello, I'm trying to create a service with JaxWS from a WSDL file. I
have completed the JAX-WS option pointing
to /home/jasanchez/cxf/cxf-2.0-incubator-RC which is the place that I
have CXF installed. Now, when I try to create the service I get the
following error:
ENTRY org.eclipse.stp.common 4 0 2007-07-02 13:49:22.500
!MESSAGE the 'IRuntimeKitProcessor' could not be instanciated from the extension org.eclipse.stp.sc.cxf.cxf. check value of the attribute 'kit_processor_class'
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.stp.sc.cxf" was unable to instantiate class "org.eclipse.stp.sc.cxf.generators.CeltixWsdlToJavaGenerator ".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.stp.sc.jaxws.runtimeprovider.RuntimeProviderMana ger.getWsdltoJavaGenerator(RuntimeProviderManager.java:232)
at org.eclipse.stp.sc.jaxws.runtimeprovider.RuntimeProviderMana ger.getWsdltoJavaGenerator(RuntimeProviderManager.java:79)
at org.eclipse.stp.sc.jaxws.wizards.wsdltojava.WsdlToJavaGenera teAction.generate(WsdlToJavaGenerateAction.java:67)
at org.eclipse.stp.sc.jaxws.wizards.wsdltojava.GenerateCodeWiza rd.performFinish(GenerateCodeWizard.java:124)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.stp.sc.jaxws.actions.WsdlToJavaAction.run(WsdlTo JavaAction.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
org.eclipse.core.runtime.CoreException[1]: java.lang.NoClassDefFoundError: org/apache/cxf/tools/wsdlto/frontend/jaxws/JAXWSContainer
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2007-07-02 13:49:22.503
!MESSAGE Plug-in "org.eclipse.stp.sc.cxf" was unable to instantiate class "org.eclipse.stp.sc.cxf.generators.CeltixWsdlToJavaGenerator ".
!STACK 0
FUDForum. Page generated in 0.02413 seconds
