Re: EMF/SDO/XSD Update Site [message #589521] |
Tue, 22 June 2004 20:32 |
Nick Boldt Messages: 481 Registered: July 2009 |
Yes, there is, for EMF, XSD and SDO 2.0.
I've updated the FAQ with details:
http://dev.eclipse.org/viewcvs/indextools.cgi/~checkout~/emf -home/faq/faq.xml#dnl1
(copied below as well)
Nick Boldt
codeslave(at)ca-ibm-com
As of June 21, 2004, there is an Update Manager site for EMF, SDO, and XSD.
This is only for the 2.x+ stream, not the 1.1.x stream.
IBM Internal can use:
* http://fullmoon.torolab.ibm.com/tools/emf/updates/
* http://emf.torolab.ibm.com/tools/emf/updates/
The rest of the world can use:
* http://download.eclipse.org/tools/emf/updates/
* http://eclipse.mirrors.tds.net/tools/emf/updates/
* (or other mirrors with similar paths. some mirrors use
/eclipse/tools/emf/updates/)
If you're not familiar with Update Manager, surf to one of the above
URLs and read the instructions there.
Please note, however:
1. You cannot upgrade from EMF 1.x to EMF 2.x, since you must also
upgrade versions of Eclipse (2.x -> 3.0).
2. If you install a stable, integration build of EMF, such as
2.0.0.I200406211000, when EMF 2.0.0 Final is launched, UM will consider
this to be an OLDER version, rather than a newer version. So, if you
wanted to use UM to stay abreast of changes between Eclipse 3.0
Milestones, when 3.0 Final was launched, you'd have to download EMF
manually and remove your 2.0.0.yyyymmddhhmm version manually anyway. The
same problem exists with updating Eclipse itself via UM to
3.0.0.yyyymmddhhmm - once 3.0.0 is launched, you won't be able to use UM
to upgrade the the Final version, since 3.0.0 < 3.0.0.yyyymmddhhmm.
However, we're planning to drop a new UM site build for every zipped
build, so you should be able to continue to upgrade without having to
download zips manually.
Arun Goyal wrote:
> I was wondering if there is a EMF update site....the default eclipse update
> doesn't
> seem to pick up new updates for EMF.
> Arun
FUDForum. Page generated in 0.02047 seconds
