Re: Running Collaboration Server Windows [message #589296 is a reply to message #589289] |
Tue, 11 October 2005 16:02 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Christian,
I forgot to also say...if you unjar this jar manually (into a directory
org.eclipse.ecf.provider_0.4.0 in the plugins directory) then you can
just comment this line out (jar xvf...) and start the server without it.
Scott
Scott Lewis wrote:
> Hi Christian,
> Christian BEZARD wrote:
>> I try to install an ecf server on Windows 2K.
>> I use Startserver.cmd, there is an error :
>> cd %PN%
>> jar xvf org.eclipse.ecf.provider_0.4.0.jar =====>> What's
>> this command.
>> cd %~dp0
> Due to a build strangeness (which is happily going away shortly), the
> org.eclipse.ecf.provider plugin had to be built as a jar (rather than in
> a directory, etc). So, since not running in Eclipse, this unjars the
> org.eclipse.ecf.provider jar so that the server classpath can include
> the provider.jar (which is inside the org.eclipse.ecf.provider_0.4.0.jar.
> Clumsy, I know, but it's just a temporary work around. It won't be in
> the next release of ECF (0.5.0).
> Scott
FUDForum. Page generated in 0.02935 seconds
