@ManyToMany kind of working... [message #588792] |
Wed, 24 May 2006 14:33 |
Kevin Sutter Messages: 106 Registered: July 2009 |
The @ManyToMany relationship is sort of being recognized. The following
code snippet (part of the Kodo tutorial) is properly recognized when
generating the ddl. That is, it created the RABBIT_CHILDREN table just
fine.
@ManyToMany
@JoinTable(name="RABBIT_CHILDREN",
joinColumns=@JoinColumn(name="PARENT_ID"),
inverseJoinColumns=@JoinColumn(name="CHILD_ID"))
private Set<Rabbit> children = new HashSet<Rabbit> ();
But, the Persistence Properties panel is still confused. That panel
doesn't show the name of any join table and, of course, it doesn't show
any of the join columns. (One time, the Persistence Panel actually came
up as Transient. When I changed it to ManyToMany, the panels came back to
"normal" -- minus the join table information mentioned earlier.)
If I try to type in the values on the Persistence Properties panel, I get
an NPE when I click to add a join column...
at
org.eclipse.dali.ui.views.JoinColumnInJoinTableDialog.popula teNameCombo(JoinColumnInJoinTableDialog.java:101)
at
org.eclipse.dali.ui.views.JoinColumnInJoinTableDialog.create DialogArea(JoinColumnInJoinTableDialog.java:76)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 802)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
at org.eclipse.jface.window.Window.open(Window.java:785)
at
org.eclipse.dali.ui.views.JoinTableComposite.addJoinColumnFr omDialog(JoinTableComposite.java:427)
at
org.eclipse.dali.ui.views.JoinTableComposite.addJoinColumn(J oinTableComposite.java:423)
at
org.eclipse.dali.ui.views.JoinTableComposite.access$2(JoinTa bleComposite.java:421)
at
org.eclipse.dali.ui.views.JoinTableComposite$2.widgetSelecte d(JoinTableComposite.java:177)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Thanks for any insights,
Kevin
FUDForum. Page generated in 0.03079 seconds
