EPF on Jazz [message #588296] |
Thu, 31 January 2008 11:01 |
Roman Smirak Messages: 136 Registered: July 2009 |
I am trying to get single eclipse for Jazz 0.6Beta2 + EPF 1.2.0.2
I have done:
1/ Added all required plugins and versions in Jazz eclipse (GEF, GMF, EMF
SDK, etc.) as extensions
2/ Created EPF 1.2.0.2 Extension (removed all Eclipse, GEF, etc. plugins,
epf plugins just left)
3/ Install manager looks OK without any errors in any extension
When I started Jazz eclipse I saw EPF perspectives added (Authorization,
Browsing); however, if I open library I get following error for every node
(plugin):
!ENTRY org.eclipse.jface 4 2 2008-01-30 20:19:42.564
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
at
org.eclipse.emf.common.EMFPlugin$InternalHelper.getString(EM FPlugin.java:725)
at
org.eclipse.emf.common.EMFPlugin$EclipsePlugin.getString(EMF Plugin.java:621)
at org.eclipse.emf.common.EMFPlugin.getString(EMFPlugin.java:45 0)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getString( ItemProviderAdapter.java:1808)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getString( ItemProviderAdapter.java:1800)
at
org.eclipse.epf.library.edit.element.ContentPackageItemProvi der.getText(Unknown
Source)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:199)
at
org.eclipse.jface.viewers.DecoratingLabelProvider.getText(De coratingLabelProvider.java:129)
at
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:351)
at
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:183)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:135)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:911)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:97)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:991)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2026)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:806)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:781)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:755)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:627)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1410)
at
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:918)
at
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1421)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:125)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7053)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1541)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5798)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3705 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5370)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Any ideas?
Roman
FUDForum. Page generated in 0.03311 seconds
