Getting all jdbc connection info in a reliable way ? [message #587426] |
Mon, 20 August 2007 08:55 |
Max Rydahl Andersen Messages: 233 Registered: July 2009 |
Is there any way to get all jdbc connection info in a reliable way from
JDBC based database connection definitions ?
I'm trying to use the DTP ui as much as possible to avoid redundant UI
about databases, but I haven't found any good way of getting jdbc
connection info to use in external programs ?
I know I can ask the Generic SQL definitions for it via some generic
properties, but all the "native" definitions does not seem to expose the
same properties.
If the above is not possible for all defintions is there a way to
query/control the UI connection chooser/definer to not use/show connection
profiles that does not expose the jdbc info ?
/max
FUDForum. Page generated in 0.02533 seconds
