Home » Eclipse Projects » Plugin Development Environment (PDE) » Absolute URLs in the config.ini generated by p2
Absolute URLs in the config.ini generated by p2 [message #586918] Thu, 11 December 2008 14:08
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
We're building our p2 product using the following command line, and the
generated config.ini contains absolute paths for the
org.eclipse.equinox.simpleconfigurator.configUrl property. I've turned
on the roaming flag.
I'm not sure whether it's p2 at fault or me. Could someone point me to
workarounds for this ?
--- begin command line args ---
-nosplash --launcher.suppressErrors
-application org.eclipse.equinox.p2.director.app.application
-metadataRepository file:${build_directory}/repo
-artifactRepository file:${build_directory}/repo
-installIU com.thoughtworks.twist.eclipse.ui.product
-version 1.0.0.qualifier
-profile TwistProfile
-profileProperties org.eclipse.update.install.features=true
-p2.os ${os} -p2.ws ${ws} -p2.arch ${arch}
-roaming
-destination ${twist-home}
-bundlepool ${twist-home}
--- end command line args ---
--- begin the config.ini file ---
#This configuration file was written by:
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser
#Thu Dec 11 19:10:15 IST 2008
eclipse.p2.profile=TwistProfile
osgi.framework=file\:plugins/org.eclipse.osgi_3.4.0.v2008060 5-1900.jar
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:../.. /../tmp/eclipse/macosx.carbon.x86/eclipse/configuration/org. eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=com.thoughtworks.twist.eclipse.ui.product
osgi.splashPath=platform\:/base/plugins/com.thoughtworks.twi st.eclipse.ui
eclipse.p2.data.area=@config.dir/../p2
osgi.bundles.defaultStartLevel=4
eclipse.application=com.thoughtworks.twist.application
--- end the config.ini file ---
-- Ketan
Previous Topic:problems with a RCP extension point
Next Topic:Transitive dependencies and optional plugins [was: IStatus not found at runtime]
Current Time: Mon Sep 20 15:31:46 GMT 2021
Powered by FUDForum. Page generated in 0.02579 seconds
