Home » Eclipse Projects » Riena » Toolbar visible function
Toolbar visible function [message #586102] Mon, 28 June 2010 10:02 Go to next message
Kim Myoungki is currently offline Kim MyoungkiFriend
I have got problem with a toolbar visible/invisible function.
I made a toolbar and the visibility is controlled by PropertyTester.
At the first, I make the toolbars invisible, and I make it visible again.
After that, I can not go back to invisible but I refresh the window the toolbar is invisible.
I think some event are not caught by Riena framework.
Is this a bug or Are there any method to achive this?
Could you give me any suggestion?
I am using Riena 2.0 and Eclipse 3.6
Thanks a lot.
Myoungki
Re: Toolbar visible function [message #586129 is a reply to message #586102] Tue, 29 June 2010 09:55 Go to previous message
Christian Campo is currently offline Christian CampoFriend
Dependens a little on what you are doing exactly. In general we only use SWT/JFace funtionality for Property testing and
that should work.
We know that Property testing with <when> closes dont work anymore once you changed the visibility of a menu item once
using the API.
I recommend you isolate a snippet and create a bug for that.
- christian
Am 28.06.10 12:02, schrieb Kim Myoungki:
> Hello,
> Thanks a lot.
> Myoungki
Previous Topic:Riena and Spring
Next Topic:Toolbar visible function
Current Time: Thu May 26 18:47:49 GMT 2022
Powered by FUDForum. Page generated in 0.02118 seconds
