Home » Archived » M2M (model-to-model transformation) » ATL Newbie
ATL Newbie [message #59101] Thu, 23 August 2007 14:29 Go to next message
Alexandre Torres is currently offline Alexandre TorresFriend
Hi. IŽm a newbie in ATL.
IŽm trying to use ATL to do a simple transform: Get a UML2 model (any
model) designed with eclipse UML and a predefined profile and transform
into a model based in a Km3 metamodel that takes some information from the
source model.
But by following the examples I could find, I canŽt find a way to use UML
2 as the source metamodel. All examples uses Km3 metamodels... so, should
I write a km3 metamodel expressing the entire UML 2!?
IŽm sure am I doing something wrong. Is there any piece of documentation
IŽm missing ?
Another question: Do I have to create km3/ecore files at all? CanŽt I use
an UML model as metamodel or generate metamodels from UML models?
Re: ATL Newbie [message #59127 is a reply to message #59101] Thu, 23 August 2007 15:39 Go to previous messageGo to next message
Ok, I found the UML 2 model in the button EMF Registry inside Run-Atl
configuration. It seems to have worked.
There is a catch: How can I know the UML structure used in EMF
implementation? is there a reference or something like that? My next step
is select objects by stereotype and get properties... now I need to learn
how to do that. Any example?
Re: ATL Newbie [message #59261 is a reply to message #59127] Fri, 24 August 2007 09:06 Go to previous message
Originally posted by: quentin.glineur.obeo.fr
--------------000805080205010906070003
Content-Type: text/plain; charset=ISO-8859-15
This discussion may help you ;) :
news://news.eclipse.org:119/f4j1m2$jv2$1@build.eclipse.org
Quentin GLINEUR
Alexandre Torres a
Previous Topic:[ATL] : Exception when using two variable in the "from" action
Next Topic:[ATL] : Insertion Order in Sequence ?
Current Time: Mon Mar 08 13:26:56 GMT 2021
Powered by FUDForum. Page generated in 0.01760 seconds
