Home » Archived » Riena » CTL+ALT+DEL on WinXP Riena Strangeness
CTL+ALT+DEL on WinXP Riena Strangeness [message #584728] Mon, 22 February 2010 00:17 Go to next message
Curious if anyone else noticed strangeness in a Riena RCP app when trying to display the winXP task manager? It appears to disable the selection of submodules within whatever module was active at the time. No other modules are affected. Using 3.5 eclipse base with a 3.6M target platform w/ riena 2.0. Tested by importing the example app and running it within the workbench.
Searching bugzilla showed some issues with CTL and various other key combinations, so I wasn't sure if this was known behavior.
Re: CTL+ALT+DEL on WinXP Riena Strangeness [message #584737 is a reply to message #584728] Mon, 22 February 2010 02:58 Go to previous messageGo to next message
Am 22.02.10 06:17, schrieb xb01000@gmail.com:
oh wow......never seen that before but I can reproduce it......You can open a bug for this or I do this...
christian
Re: CTL+ALT+DEL on WinXP Riena Strangeness [message #584748 is a reply to message #584737] Mon, 22 February 2010 07:53 Go to previous messageGo to next message
Am 22.02.10 08:58, schrieb Christian Campo:
> christian
I have added a bug for this https://bugs.eclipse.org/bugs/show_bug.cgi?id=303476
Re: CTL+ALT+DEL on WinXP Riena Strangeness [message #584758 is a reply to message #584728] Tue, 23 February 2010 00:53 Go to previous message
Thank you.
Previous Topic:Riena 2.0.0.M5
Next Topic:CTL+ALT+DEL on WinXP Riena Strangeness
Current Time: Sun Nov 02 11:58:47 EST 2025
Powered by FUDForum. Page generated in 0.04112 seconds
