Home » Eclipse Projects » Riena » Riena 2.0.0.M5
Riena 2.0.0.M5 [message #584640] Tue, 02 February 2010 14:17 Go to next message
Christian Campo is currently offline Christian CampoFriend
Hi Rienaers,
a new version of Riena is available. Riena 2.0.0.M5 as part of the M5 milestone in Helios.
New and Noteworthy can be found here http://wiki.eclipse.org/Riena_New_And_Noteworthy#2.0.0.M5
Links to updatesite and target platform are available here http://wiki.eclipse.org/Riena_Getting_started
We started a migration guide from 1.2. to 2.0 over here http://wiki.eclipse.org/Riena_Migrating_to_2.0_from_1.2 . Its
still very small.
We noticed an issue with the 2.0.0.M5 Riena update site that only exists under Eclipse 3.6M5. There is a bug that tracks
this problem https://bugs.eclipse.org/bugs/show_bug.cgi?id=301534 .
We hope we get a hint how to fix or work around it pretty soon.
2.0.0.M5 contains a lot of new features like
- controller testing
- a new visual for error marking
- a new hessian version 3.2.0 (which unfortunatelly requires 3.2.0 on both sides client and server)
- an ImageButton (an image that acts like a button)
- many many improvements in the area of MasterDetail
You find all the details in the New and Noteworthy linked above.
If you have any feedback, let us know.
thanks
christian campo
Re: Riena 2.0.0.M5 [message #584716 is a reply to message #584640] Mon, 08 February 2010 14:54 Go to previous message
Am 02.02.10 15:17, schrieb Christian Campo:
> Hi Rienaers,
> http://wiki.eclipse.org/Riena_Migrating_to_2.0_from_1.2 . Its still very
> small.
> under Eclipse 3.6M5. There is a bug that tracks this problem
> thanks
> christian campo
While the problem for Eclipse 3.6M5 is still not fixed, you can install Riena from the Helios 3.6M5 repository. There
you can find Riena and update from there.
christian
Previous Topic:Riena 2.0
Next Topic:CTL+ALT+DEL on WinXP Riena Strangeness
Current Time: Sun Oct 13 19:41:00 GMT 2024
Powered by FUDForum. Page generated in 0.03840 seconds
