Home » Eclipse Projects » Plugin Development Environment (PDE) » What is the most efficient way to debug plug-ins?
What is the most efficient way to debug plug-ins? [message #584336] Wed, 05 November 2008 15:16
Derek Palma is currently offline Derek PalmaFriend
I want to make sure I have the most efficient approach. The documentation
says you must use Debug As->Eclipse Application to run your plug-in code in
the debugger. This seems to another instance with your workspace plugins in
a new instance of Eclipse. Is there any way I can avoid the startup time hit
of starting another instance and have it be more like just executing a Java
application from with-in my Eclipse workspace? I noticed Rose has a feature
called pluglets and the documentation mentions that pluglets specifically
avoid this issue.
Should I just debug all my code inside a Java app and then do the plugin
integration testing last? I could also keep all my working plugins installed
versus in my workspace.
Thanks for your help.
Derek Palma
Previous Topic:What is the most efficient way to debug plug-ins?
Next Topic:remove unnecessary plugins
Current Time: Sun Sep 19 20:26:06 GMT 2021
Powered by FUDForum. Page generated in 0.01940 seconds
