Re: Error: The attribute argNames is undefined [message #59012 is a reply to message #58934] |
Mon, 12 December 2005 15:57 |
Originally posted by: andrew.acooke.org
did you find a solution to this?
i have been having problems with my system (win2000) being unstable, so
updated to eclipse 3.1.1, java 1.5.0-06, and the latest ajdt build
(20051208103628), and now see the same problem.
andrew
Re: Error: The attribute argNames is undefined [message #59037 is a reply to message #59012] |
Mon, 12 December 2005 16:16 |
> andrew
We discovered that this problem occurs if there are multiple versions of
aspectjrt.jar around. In Didier's case there was a version in the AJEER
framework he was also using. The argNames annotation value only exists
in very recent aspectjrt.jar files. Can you try removing/readding the
aspectj nature to your projects and check it picks up the latest (i.e.
the version from the latest org.aspectj.runtime plugin). Do you have a
copy of aspectjrt.jar anywhere else accessible by your project? Is it
breaking when you build or when you run?
Andy.
Re: Error: The attribute argNames is undefined [message #59062 is a reply to message #59037] |
Mon, 12 December 2005 17:25 |
perfect - thanks! it was indeed a aspectjrt.jar from a previous version
(i need to work out how to use eclipse better).
cheers,
andrew
ps it was during the ant build, which had a classpath that differed from
eclipse.
pps thanks for the very quick reply - i posted, went down the road for a
beer and sandwich, and then found your answer. :o)
Re: Error: The attribute argNames is undefined [message #591101 is a reply to message #58934] |
andrew
Re: Error: The attribute argNames is undefined [message #591125 is a reply to message #59037] |
cheers,
andrew
eclipse.
FUDForum. Page generated in 0.03818 seconds
