Home » Eclipse Projects » DSDP - Target Management » How to export the RSE as an eclipse RCP production?
How to export the RSE as an eclipse RCP production? [message #583650] Mon, 30 August 2010 09:37 Go to next message
boyeestudio is currently offline boyeestudioFriend
Dear all guru:
I use the RSE for several months,And for my work purpose,I need a Client to connect to the DStore.So I try to export the RSE as an eclipse RCP product and run it independently but I failed to do that. pls any guru give some advice on it. many thanks!
Re: How to export the RSE as an eclipse RCP production? [message #583693 is a reply to message #583650] Mon, 30 August 2010 18:12 Go to previous message
David McKnight is currently offline David McKnightFriend
Could you provide more information as to what failed? Does RSE and/or it's
dependencies not load or is this an issue of not being able to connect?
"boyeestudio" <gaoyuanxue118@gmail.com> wrote in message
news:i5fu4i$eb4$1@build.eclipse.org...
> Dear all guru:
Previous Topic:CDT launch using RSE
Next Topic:Execute command or script after SSH connection
Current Time: Thu Apr 02 01:03:19 GMT 2020
Powered by FUDForum. Page generated in 0.01358 seconds
