Home » Eclipse Projects » EGit / JGit » Import remote git repository in one folder and create project in another one
Import remote git repository in one folder and create project in another one [message #581953] Tue, 06 July 2010 08:05 Go to next message
Dmitry  is currently offline Dmitry Friend
is it possible to import remote git repository to one folder, for example /home/user/git,
and then create java project in another folder, for example /home/user/eclipse, so that no further actions will be required to make them work together?
If I try to do like that:
1) my project is not "shared" automatically (it doesn't matter what settings I select in "Import projects from Git" wizard)
2) I can not share project with just imported repository (if they are located in different folders).
Why does egit require to have git repository in the same folder where project is?
I understand that I can clone just imported repository to the project folder, but still, why does egit have such limitations?
Re: Import remote git repository in one folder and create project in another one [message #582001 is a reply to message #581953] Tue, 06 July 2010 18:26 Go to previous message
Robin Rosenberg is currently offline Robin RosenbergFriend
Dmitry wrote:
> /home/user/git, and then create java project in another folder, for
> settings I select in "Import projects from Git" wizard) 2) I can not share
> folders).
> project is? I understand that I can clone just imported repository to the
I can answer that one: Because noone did the required coding.
JGit has support at the lower levels, so it is just that some wants to
spend an hour (or a few) on it instead of on something else.
-- robin
Previous Topic:Import remote git repository in one folder and create project in another one
Next Topic:Automatically share projects imported in eclipse
Current Time: Thu Oct 21 06:30:53 GMT 2021
Powered by FUDForum. Page generated in 0.02756 seconds
