Home » Archived » EPP » Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies?
Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580025] Fri, 12 February 2010 16:34 Go to next message
Marin  rli? is currently offline Marin rli?Friend
Member
Hi all,
I'm having a bit of a problem updating Eclipse MT from 3.5.0 to 3.5.1. I've followed the forums with all the update site issues over the summer, but I think this is some other issue. When trying to update configuration, 3.5.1 is found in the update site (only main Galileo update is enabled), but won't update:
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse Platform SDK 3.5.1.M20090917-0800 (org.eclipse.platform.sdk 3.5.1.M20090917-0800)
Software currently installed: Eclipse Modeling Tools 1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)
Only one of the following can be installed at once:
org.eclipse.platform_root 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ
org.eclipse.platform_root 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
Cannot satisfy dependency:
From: Eclipse Modeling Tools 1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)
To: org.eclipse.epp.package.modeling.feature.feature.group [1.2.0.20090618-1854]
From: EPP Modeling Feature 1.2.0.20090618-1854 (org.eclipse.epp.package.modeling.feature.feature.group 1.2.0.20090618-1854)
To: org.eclipse.platform.feature.group [3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ]
From: Eclipse Platform 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ (org.eclipse.platform.feature.group 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ)
To: org.eclipse.platform_root [3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ]
From: Eclipse Platform 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7 (org.eclipse.platform.feature.group 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7)
To: org.eclipse.platform_root [3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7]
From: Eclipse Platform SDK 3.5.1.M20090917-0800 (org.eclipse.platform.sdk 3.5.1.M20090917-0800)
To: org.eclipse.platform.feature.group [3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7]
Seems like a circular dependancy to me (?) Is there a way to update EPP Modeling AND Eclipse Platform at once? If it's some other plugin that is fixed on using exactly 3.5.0 and nothing else, shouldn't it be listed here?
It's a bit annoying, I'm trying to figure this one out for 3 months on and off now, and I really don't want to screw up my platform by brute-force upgrade, I've grown fond of it ;)
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580072 is a reply to message #580025] Sun, 14 February 2010 22:03 Go to previous message
David Williams is currently offline David WilliamsFriend
Its not exactly a circular dependency, just that directly, or
indirectly, a couple of features say they need exactly some version of
org.eclipse.platform_root.
I'm not really heard of updating a "package" before (everything in the
package could update, but didn't know the "package" feature itself is
installed. Did you get that from 'unziping' the modeling package? Or did
you start off with platform, then install the modeling package from a repo?
Practically, you might go to Galileo site and "installing" just the
platform update ... then use further passes to install/update other
pieces. If any one piece of it installs, it should be ok, without fear
of breaking the install. (At least, that's supposed to be the
magic/justification for p2!)
HTH
Previous Topic:Regarding UDC in RCP
Next Topic:Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies?
Current Time: Sun Apr 14 10:24:19 GMT 2024
Powered by FUDForum. Page generated in 0.02645 seconds
