Home » Eclipse Projects » EGit / JGit » Preferences->Label Decorations->Git won't "stick"
Preferences->Label Decorations->Git won't "stick" [message #578478] Wed, 24 March 2010 20:08 Go to next message
buzzkill is currently offline buzzkillFriend
I can't get the label decorations to stick. I select the Preferences->Label Decorations->Git check box, but the setting won't apply and just reverts back to unchecked.
Everything is selected in Team->Git->Label Decorations.
The Import->Git->Git Repository worked fine, and all the files are imported correctly into the project..
Also, Team->Commit... is greyed out for all files, as well as Push. However, compare and history work fine... (if this is a separate problem, I will post separate topic).
I'm using Eclipse 3.5 with CDT and Egit using ubuntu 8.0.4.
Any ideas or simple fixes?
buzz
Re: Preferences->Label Decorations->Git won't "stick" [message #578893 is a reply to message #578478] Tue, 06 April 2010 14:46 Go to previous message
Stefan Lay is currently offline Stefan LayFriend
"buzzkill" <destrozyk@yahoo.com> wrote in message
news:hodrgc$qeo$1@build.eclipse.org...
There is a known bug in case that there is a .git folder somewhere below a
eclipse project (https://bugs.eclipse.org/bugs/show_bug.cgi?id=297163). Do
you have that in your case?
Do you have any entries in the error log?
Stefan
Previous Topic:Deleting Branches
Next Topic:Re: Preferences->Label Decorations->Git won't "stick"
Current Time: Sat Jun 06 09:12:42 GMT 2020
Powered by FUDForum. Page generated in 0.02005 seconds
