Error initializing parser for input [message #577846] |
Thu, 03 June 2010 11:22 |
Magisterion Messages: 10 Registered: June 2010 |
I'm trying to use the last IMP build to create new Language for Eclipse 3.5.
When i try to test plugin for my JScript file flash_commands.js - i got Coloring, but nothing else (i create plugins for outline and etc - how said at documentation). And there is the next errors:
Error initializing parser for input flash_commands.js:
org.eclipse.imp.model.ModelFactory$ModelException: No such element:
at org.eclipse.imp.model.ModelFactory.doOpen(ModelFactory.java: 127)
at org.eclipse.imp.model.ModelFactory.open(ModelFactory.java:12 2)
at org.eclipse.imp.editor.UniversalEditor.initializeParseContro ller(UniversalEditor.java:730)
at org.eclipse.imp.editor.UniversalEditor.createPartControl(Uni versalEditor.java:693)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3506)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
is this normal? If not - how to fix this?
FUDForum. Page generated in 0.03483 seconds
