Home » Archived » Voicetools » FYI: how to update an openvxml application in Tomcat
FYI: how to update an openvxml application in Tomcat [message #577016] Wed, 11 June 2008 16:23 Go to next message
Randy Childers is currently offline Randy ChildersFriend
This is just an FYI for those who aren't intimately familiar with the way
Tomcat works.
There's something tricky about redeploying a new version of an application
to a Tomcat installation; there is an internal cache which, if you don't
explicitly delete it, you can delete the folder with the same name in the
webapps directory and replace the existing .war, but you'll actually be
using the previous version of the application still in the cache. The
routine I follow to avoid this is:
(assume for this example that we're updating acme.war)
1. Stop the Tomcat service
2. In the Tomcat\webapps folder, delete the acme.war file and the acme
folder
3. In the Tomcat\work\Catalina\localhost folder, delete the acme
folder (this is the cache)
4. Copy in the new acme.war to the webapps folder
5. Start the service
6. Wait a little while for Tomcat to unpack the .war and get things ready
to serve VXML
Randy
OpenMethods
Re: FYI: how to update an openvxml application in Tomcat [message #1016110 is a reply to message #577016] Tue, 05 March 2013 06:16 Go to previous message
sonali shinde is currently offline sonali shindeFriend
I am using open vxml 4.0 perspective, eclipse indigo 3.7. I m trying to run xml file but there are no results..
Previous Topic:No openvxml perspective
Next Topic:FYI: the URL to use for your openVXML application
Current Time: Tue Apr 16 11:11:58 GMT 2024
Powered by FUDForum. Page generated in 0.20341 seconds
