Possible performance bug in LPG? [message #575560] |
Wed, 24 June 2009 18:22 |
Dieter Kleinrath Messages: 5 Registered: July 2009 |
While trying to improve the performance of my LPG parser I think I found=
a =
serious performance bug in LPG.
Actually I can not believe that this wasn't mentioned before so if this =
is =
known or if it is intended behaviour please appologize.
The problem arises if the same generated parser is reused to parse sever=
al =
files. When a file is parsed with lpg.runtime.DeterministicParser it fir=
st =
calls the method lpg.runtime.Stacks.reallocateStacks(). Here is the code=
from this method:
int old_stack_length =3D (stateStack =3D=3D null ? 0 : =
stateStack.length),
stack_length =3D old_stack_length + STACK_INCREMENT;
if (stateStack =3D=3D null)
stateStack =3D new int[stack_length];
locationStack =3D new int[stack_length];
parseStack =3D new Object[stack_length];
else
System.arraycopy(stateStack, 0, stateStack =3D new =
int[stack_length], 0, old_stack_length);
System.arraycopy(locationStack, 0, locationStack =3D new =
System.arraycopy(parseStack, 0, parseStack =3D new =
Object[stack_length], 0, old_stack_length);
return;
As you can see if the stateStack was already created, the parser will co=
py =
its contents into a new array with the size =
old_stack_length+STACK_INCREMENT. This is done because the =
reallocateStacks() method is also used to resize the stack when needed. =
This behaviour results in a memory leak and in serious performance =
problems when reusing a parser instance for compiling more than one file=
After I changed my code to not reuse the parser the compilation time for=
about 200 files was reduced from 10 seconds to under one second so it is=
now 10 times faster.
The ParseController that gets generated by IMP also lazily instantiates =
the internal DeterministicParser. So perhaps IMP suffers the same =
performance problems (I'm not sure if IMP reuses the ParseController).
If someone can confirm that this is a bug I'll create a bug report for i=
t.
Greetings,
Dieter
FUDForum. Page generated in 0.02527 seconds
