Re: Capturing annotations [message #57972 is a reply to message #57950] |
Wed, 26 October 2005 14:49 |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Ben,
The best place to look for things like this is the developer's notebook,
such as:
http://eclipse.org/aspectj/doc/next/adk15notebook/annotation s-pointcuts-and-advice.html
Look for the context exposure subsection - near the end of that is a
snippet that uses thisJoinPointStaticPart.getSignature() to get the
corresponding
java.lang.reflect.Method object, then you can call
getAnnotation/getAnnotations on that.
BTW, the aspectj-users list is best for language questions. This newsgroup
is primarily for AJDT-specific stuff. We do try to monitor both, but the
mailing list has a bigger audience so you might get a faster/better
response.
Matt.
Benjamin Podszun wrote:
> Hi there.
> New to AspectJ I did some basic examples and now I want to use it to solve
> real problems ;)
> For my current work I planned to tag some methods with annotations to
> provide security checks without implementing those several times. Is this
> a good practice at all?
> First tests work so far, but I'd like to use the information in my
> annotation for the advice. Example:
> @Guarded("AdminsOnly")
> public void whatever() {}
> I can match this join point using call(@Guarded * *(..)), but I see no way
> to access the string value (or other values) later.
> before() : call(@Guarded * *(..)) {
> // I want to access the annotation here..
> Using Google I always end up with the annotation-based way of using
> AspectJ, the only usable info was http://ramnivas.com/blog/index.php?p=10
> - but that's only a proposal and over a year old.
> Can anyone lend me a helping hand here and tell me if it's a)
> viable/okay/good practice to do what I plan to do here and b) how one is
> supposed to access annotations of thisJoinPoint?
> Thanks in advance,
> Ben
Re: Capturing annotations [message #590690 is a reply to message #57950] |
Hi Ben,
such as:
corresponding
response.
Matt.
> Hi there.
> real problems ;)
> Thanks in advance,
> Ben
FUDForum. Page generated in 0.02597 seconds
