More tips for the sample code [message #572297] |
Wed, 26 September 2007 19:44 |
James Messages: 272 Registered: July 2009 |
I have found several more issues relating to focus and the SWT/Swing
integration. I have breifly outlined each issue below and posted my code
modifications at the bottom. I suspect I may not be clear enough in
describing both the issues, the solutions, and how they work, so please ask
any questions you might have. I would imagine others have periodically
noticed at least some of these issues as well.
Any thoughts on these Gordon?
My workarounds affect EmbeddedSwingComposite, SwtFocusHandler, and
AwtFocusHandler classes.
The issues:
#1
When using keyboard navigation, the default code misses sending the focus to
the AWT control on its first pass through (the returned focus component is
null). This can be solved by setting awtHasFocus to true at the top of the
gainFocus method instead of at the bottom. This will ensure that an attempt
is made to find a focusable swing control on the first focus attempt.
#2
I use an EmbeddedSwingComponent as the full contents of an editor
(consequently, the IWorkbenchPart's setFocus method sets the focus to the
EmbeddedSwingComponent). When issue #1 is fixed (ie, the AWT control
automatically gets the focus when the SWT control gets the focus), there is
occasionally a deadlock in Java 1.6 when several editors are opened at once
(even though only asycExec and invokeLater calls are used). The deadlock is
happening way down in AWT Code in the WPanelPeer class and is triggered by
the component.requestFocus inside of the awtHandler's gainFocus method.
This seems to be solved when issue #3 is solved.
#3
When the EmbeddedSwingComponent is the only focusable component inside of a
Tab Folder, the awtHandler.gainFocus call causes a malfunction in keyboard
navigation. When the tab labels get the focus (a tab's label is
underlined), typically one can switch between tabs by using the arrow keys
and then dive into the current tab using the 'tab' key. To do this, the SWT
Tab Folder seems to momentarily set the focus to the tab's contents and then
return focus to the tab label.
The problem is that we are telling AWT to take the focus when the tab's
contents gets the focus, so the focus doesn't go back to tab's label. I
have added set/get AbortFocus methods to the SwtFocusHandler. The abort
focus value is set whenever the SWT Control's focus is gained or lost. This
way if the SWT control loses focus before AWT has a chance to set its focus
we can decide not to set the AWT focus.
I suspect the deadlock also has something to do with this quick transfer of
focus.
#4
There is a memory leak when you dispose of the SWT Control even if you set
the frame to null. This leak is present in Java 1.5 update 11 and Java 1.6.
To remove the memory leak, the frame needs to have its FocusableWindowState
set to false and it should be disposed of when the EmbeddedSwingComponent is
disposed of. The frame should be disposed of in the Swing EDT.
In EmbeddedSwingComposite:
public EmbeddedSwingComposite(Composite parent, int style) {
super(parent, style | SWT.EMBEDDED | SWT.NO_BACKGROUND);
getDisplay().addListener(SWT.Settings, settingsListener);
setLayout(new FillLayout());
this.addDisposeListener(new DisposeListener()
public void widgetDisposed(DisposeEvent e)
final Frame frame = getFrame();
Runnable disposeEDTRunnable = new Runnable()
public void run()
disposeInEDT(frame);
if (SwingUtilities.isEventDispatchThread())
disposeEDTRunnable.run();
else
SwingUtilities.invokeLater(disposeEDTRunnable);
currentSystemFont = getFont();
private boolean awtDisposed = false;
public void disposeInEDT(Frame frame)
if (!awtDisposed)
awtDisposed = true;
if (frame != null)
frame.setFocusableWindowState(false);
frame.setFocusable(false);
frame.setEnabled(false);
getRootPaneContainer().getRootPane().getContentPane().remove All();
frame.removeAll();
frame.dispose();
A summary of my code changes below:
In AwtFocusHandler
public void gainFocus() {
assert frame != null;
// assert !awtHasFocus;
assert EventQueue.isDispatchThread(); // On AWT event thread
if (getSwtHandler().getAbortFocus())
awtHasFocus = false;
return;
awtHasFocus = true;
In SwtFocusHandler:
public void focusGained(FocusEvent e)
assert awtHandler != null;
assert Display.getCurrent() != null; // On SWT event thread
setAbortFocus(false);
System.out.println("Gained: " + e.toString() + " (" +
e.widget.getClass().getName() + ")");
EventQueue.invokeLater(new Runnable() {
public void run() {
System.out.println("Gain Focus - SWT Focus Handler EDT");
awtHandler.gainFocus();
private volatile boolean abortFocus = false;
public boolean getAbortFocus()
return abortFocus;
public void setAbortFocus(boolean abort)
this.abortFocus = abort;
public void focusLost(FocusEvent e)
setAbortFocus(true);/*
System.out.print("Focus Control: ");
System.out.println(e.display.getFocusControl());
System.out.println("Lost: " + e.toString() + " (" +
e.widget.getClass().getName() + ")");*/
FUDForum. Page generated in 0.02900 seconds
